No Start.
  • Mike B.
    • Jan 2006
    • 987
    Did you bypass the 'start' relay?
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      id like to thank TJ Lathrop (digitalwave) for telling me how to bypass the starter relay (which blew my #10 fuse) AND checking all my fuses and telling me they were good.
      the starter now spins but doesnt engage to the flywheel. i really hope that i dont need to take the plenum off to get to the starter. sounds like it could be backwards but i dont think i would do that! does anyone use spacers on the starter when mounting it?
      • EtaSport
        • 2853
        hmm, i would have never thought of that, I didnt know your car was an auto. As for the starter, sounds like the pull in isnt working. Which flywheel/clutch combo are you using? Im using m50 starter, s50 flywheel and clutch and my starter makes a horrible noise when I turn the engine over (e30 transmission). I tried to use spacers on the starter and it did nothing.
        Im going to be swapping for an m20 starter, flywheel and clutch.
        Old and improved:
        • DEV0 E30
          • Oct 2004
          • 8904
          x2
          And, it spins freely by hand right?
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            it does spin by hand. Im using the M20 starter, clutch and flywheel. im thinking that the flipout selonoid is bad. ill have to change to another starter.
