Odometer Inaccurate
  • WillisE30
    • Jan 2007
    • 831
    Odometer Inaccurate
    I just got my )BDI S52 swap running and driving yesterday(e34 harness, 413 DME), and I noticed that the odometer is running quite a bit faster than it should. I'm not too concerned about the fact that I'm running my mileage up but I'd like to figure out the problem so I can accurately calculate fuel economy and oil change intervals. The vehicle speed on the speedometer does not seem to be effected. Just wondering if anyone has any insight into this problem. Thanks.
    sigpicFormer professional wrench thrower.
    Current:
    1988 325is S52
    Former:
    2008 Sparkling Graphite M3 Sedan(victim of home ownership)
    1988 M5
    1996 328is
  • BingM3
    • 863
    Stock speedo?
    • WillisE30
      • Jan 2007
      • 831
      Originally posted by BingM3
      Stock speedo?
      Yes sir. Stock 88 325is cluster.
      Current:
      1988 325is S52
      Former:
      1988 M5
      1996 328is
      • BDSax
        Junkyard King
        • Mar 2006
        • 3594
        isnt the odometer controlled by the speed control on the back of the diff?
        • WillisE30
          • Jan 2007
          • 831
          Yeah, I am dumb. I checked it with GPS and against mileposts last night. It's right on. I guess I've just been driving it a lot more than I thought.
          Current:
          1988 325is S52
          Former:
          1988 M5
          1996 328is
          • vtman05
            • 86
            I searched the treads and this has come as close as I can get to my problem. My odometer and trip meter are reading 3x what I am traveling. I can not wrap my head around why this or how this could be happening. Anyone have any ideas?
            • Uber E30
              • 1409
              Perhaps this?
              -Alex
              • WillisE30
                • Jan 2007
                • 831
                If you mix up some wiring on the connector from the motor harness to the body harness you can have that happen. When I first got my car together I had the wiring for the tach and whatever drove the trip odo mixed up. Double check things as lots of those wires are the same color.
                Current:
                1988 325is S52
                Former:
                1988 M5
                1996 328is
                • hoveringuy
                  • Dec 2005
                  • 2744
                  On a different slant to this, I was asked if my circuit would also adjust speedometer inaccuracy for larger wheelsets. It won't, but I thought there are plenty on the market that do that.
                  After some more digging, I found that those all cost $200 or so. I kinda pissed about that so I'm ordering a few chips and I'll play with making a speedometer correction circuit when I have time. It would be much, much less!
