Getrag 240 m52 swap driveshaft and tranny questions
  • 318isbmw
    • Nov 2005
    • 2842
    Mk, so I've done a bit of research and it seems that the 240 will work, but can't find anyone saying which tranny mounts to use and it looks like people are using the e36 325i driveshafts. Is this correct and what tranny mounts...
    Thanks
  • asubimmer
    • 6482
    I'm using the stock mounts and a e36 5spd driveshaft. You will also need the e30 325 selector rod and carrier.
    • Jean
      • 18228
      Are you sure getrag 240 will bolt to m50? I gotta look in the e30 resto book, I think it mentioned there is more than one type of 240, different bell housing maybe...
      • e30_kid89
        • Apr 2006
        • 489
        Lemme see I can answer all your "Using The Getrag 240" questions.
        -YES the Getrag 240 (from 90-91 318i/iS WILL bolt up to all M/S/50/52 blocks perfectly and will even line up correctly with the oil pan holes. Im not sure about the transmission form the early 318's.
        -Use the pilot bearing that was ment for your motor.
        -People have used the m20 325i shift linkage along with it, it didnt work for me so I shortened the 318 carrier and selector rod to work.
        -Use the E36 325i 5spd driveshaft with a e30 center bearing for best fitment. The E30 325i 5spd driveshaft can be used too.
        -If you're going to be running a single mass m20 flywheel use the euro 323i throw out bearing. Otherwise the stock one from the 240 should work with the m50 dualmass flywheels.
        -For transmission support use the stock unmodified e30 transmisson brace with the stock 240/e36 transmisson mounts.
        I think that should answer your questions.
        • asubimmer
          • 6482
          yes thats what I'm running. The m42 and m50 blocks are VERY similar in design. The early 240 is the same internally as the late but it has a diff bell housing and won't fit.
          • golde30
            • 11464
            interesting....what is the gearing like on the 240 compared to the 260? if i ran the 240 tranny with my big case 3.73 diff would i get a higher top speed?
            IG: @Baye30
            • BrandC
              • Jul 2006
              • 444
              SPECIFICATIONS SALES FIGURES PRICING COLORS 318i (1984-1985) ENGINE/TRANSMISSIONM10 1766cc SOHC chain-driven inline 4, 2 valves/cylinder, cast crankshaft101 hp @ 5800 RPM103 lb-ft torque @ 4500 RPM…
              240 gearing is very similar to 260. 1-3rd gear on the 240 are a tiny bit taller than 260's, maybe going 2-3 mph higher in each gear. It is actually a pretty good option paired with an M/S50/52 + 3.73 final drive.
              If I went 6-cyl on my 318is I'd keep my 240 and keep the 4.10LSD too...lots of fun!
              -Brandon
              • asubimmer
                • 6482
                yeah I have a 3.73lsd also and I love the gearing.
                • e30_kid89
                  • Apr 2006
                  • 489
                  ^^^^ Yes, the 3.73 lsd with the 240 is the bomb. I ran this combo as well
                  • 318isbmw
                    • Nov 2005
                    • 2842
                    So stock tranny mount works, awesome that saves a ton of work with this setup.
                    Thanks
                    • pogiboy9
                      • 475
                      What about the Tranny in my 84 325e?
                      http://www.decal-spec.com
                      • asubimmer
                        • 6482
                        it will work but it will sit at an angle just like the 325i's 260.
                        • 318isbmw
                          • Nov 2005
                          • 2842
                          one last question... So I can run an m50 dual mass w/ m50 clutch and m42 throwout bearing inside the 240's bellhousing, and can also run the stock mounts, so why would it be changed if all the same mounts are used. howcome I can't use the stock driveshaft and linkage if the mounts are the same, or am I missing something here that has to be modified?
                          • 318isbmw
                            • Nov 2005
                            • 2842
                            Nevermind, I just noticed the e36 tranny mounts, now I get it.
                            But the m/s50 clutch will fit inside w/ the m50 flywheel?
                            • asubimmer
                              • 6482
                              as long as its the 228mm clutch you should be fine. But why not run the e30 325 single mass flywheel and clutch? Its a heck of a lot lighter than the dual mass and is the same size. I am running a m20 single mass flywheel, IE/Clutchnets sprung 6 puck 228mm clutch, euro 323 TOB, and the getrag 240. It r3vs and grabs very nice. You can even lighten the m20 flywheels a good amt if you want too.
                              And the stock m42 driveshaft, carrier and shift linkage are too long w/ the i6.
