Quietest electric fan?
  • Funkmasta
    • May 2004
    • 7185
    I need to use an Electric fan, and mine is SO loud.
    I want one that is quiet, but still has the CFM to keep my E30 cool. Suggestions?
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
  • SchnellerVert
    • Sep 2005
    • 3948
    curved blades will be quieter. I would rather mine sounding like the front end was spooling up than worrying about overheating.
    • Funkmasta
      • May 2004
      • 7185
      Mine sounds like a jet engine...
      That Guy.
      • SchnellerVert
        • Sep 2005
        • 3948
        Mine too, But I only have a 12" fan. I was debating on modifing an E36 unit to see if it will fit. The seem not to fail as badly as E30 units.
        • Funkmasta
          • May 2004
          • 7185
          the one I am using right now is from an E24? I dont remember. I have it hardwired directly, and when it is on, it is louder than the motor.
          ... and I have to run it all the time :(
          That Guy.
          • SchnellerVert
            • Sep 2005
            • 3948
            Older coolant? clogged radiator? It should not need to be on all the time.
            • Funkmasta
              • May 2004
              • 7185
              M30... I dont need it @ speeds over 20mph, but it is annoying to turn it on and off.
              That Guy.
              • Van Westervelt
                • 9365
                You are worried about the noise from your fan when you have straight pipes?
                • Funkmasta
                  • May 2004
                  • 7185
                  It's muffled now ;)
                  That Guy.
                  • mazur
                    • Jan 2006
                    • 731
                    I'm using a straight blade 16'' slim Spal fan. I can only here it if I'm standing out side my car and/or the engine is off.
                    • equate975
                      • Jun 2004
                      • 3382
                      Joe, your a waffleswaffleswaffleswaffleswaffles.
                      You will have to see my fans when you come back. So loud it chatters your teeth, and I love every second of it.
                      Rollin' with a Geistkuchen
                      • matt
                        • 3731
                        My fan is really quiet...
                        (I don't have a fan.)
                        • SchnellerVert
                          • Sep 2005
                          • 3948
                          You also have a slightly larger core radiator correct? Do you have an oil cooler?
                          • matt
                            • 3731
                            Nope. Stock e36 radiator. No oil cooler.
                            I just don't get stuck in traffic. EVER.
                            I have had to pull off and run the heater before, but only once. I am also pretty bold about jumping into the HOV lane for a half mile to run the temps down.
                              • 34839
                              I have a flexalite 16" curved blade fan, 2010cfm at 13amps. next time I will go for the 2500cfm version at 17 amps, although the 2000 has been enough so far (just barely). you can hardly hear it over the motor.
