For those of you who have kept the OBD2 for your swaps, how did you wire in your EWS components considering it's not part of the engine harness? Any other wire issues?
Swaps using OBD2
Originally posted by E30 Memorial View PostFor those of you who have kept the OBD2 for your swaps, how did you wire in your EWS components considering it's not part of the engine harness? Any other wire issues?
I have heard from others that a Turner chip can disable ews fo obd-2. I may go this route if after some more reasearch it is feasable.
I thought that as well until someone recently posted that info. Like I said, I would have to do more reasearch, but someone has said it is possable, that and m50 manifold for the increase in HP, but, again, unfounded info from r3v. It was posted somewhere in 24v swaps, I did post in it, check my profile, search pssts by me. Within last 5-7 days.
Wiring EWS is simple. It just takes a little more time and you need the correct componants. It is a must to have the EWS module and key from the engine you are swapping into the E30. The ring antenna and the transmit/receive box can be from any car, but if they have the module and key, then they should have these componants available as well.
Here is the diagram I used for my S50B32 swap.
^^ just was i was looking for. Thanks for the two of you. i should start my swap very soon.No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5Rs
Thanks for the basic hookup info, it really simplifies it. I guess my main question would be what has been used for the actual wiring hookup between the EWS components and the engine harness. Was the E36 under dash wire harness torn apart just for the EWS wiring? Or was each component (ignition ring, transmitter, EWS module) connector/plug from the E36 harness cut off with several inches of wire and a harness made to tie into the OBD2 engine harness? Basically how would I interface the EWS components with OBD2 engine harness in an E30.Steve
'89 332i
'90 M3
'01 530is
'24 MC JCW
'13 ZL1 Camaro
'18 RAM 3500
