AKG's adapter
    • 37832
    AKG's adapter
    Just thought I would let you guys know that we got it over at the shop yesterday. It's junk! Yes, it does work though. It look like they used all used junkyard parts for the connectors and wiring. They did not even solder the wired together, only butt connected. All of the extra wired were not removed and were just sitting in there. The best part, it was wrapped in electrical tape! Definitely not a clean adapter, the one I made for my 85 325e's i motor swap is nicer!
    Anywho, just letting everyone know!
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    wow, thats pretty sad. it is half the price i guess for a reason
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      I'd love to see shots if ya got any...
      • matt
        • 3731
        Shocking. :rolleyes
        Treehouse is the best for a reason.
          • 37832
          Originally posted by matt
          Shocking. :rolleyes
          Too bad it still isn't worth $400, no matter what you try to tell me.
          As far as AKG's adapter, no real loss. They cost was split between 3 people.
          Maybe I can get pics at some point.
          Grover Beach, CA
          www.BimmerHeads.com
          • Van Westervelt
            • 9365
            According to Luke, butt splices are superior to soldered joints like that.
              • 37832
              I don't buy it.
              Grover Beach, CA
              www.BimmerHeads.com
              • matt
                • 3731
                I would tend to agree with that. It's still no good to use used connectors, used wire, used pins...
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  Originally posted by MR 325
                  I don't buy it.
                  VVVVvvvvvVVvvvvvVVvvvibration?
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    Whats wrong with used? It's not like engine bay gunk on exposed wires causes changes in resistance for precise electronics.
                    • 1990m3
                      • 1180
                      solder can change the resistance being sent through wires. For some sensors that can give you faulty readings, therefore crimping is useful. Soldering is good for wires that pass current as opposed to measuring resistance. Plus, solders can break
                      • whowhatwhere
                        • Aug 2007
                        • 259
                        Is the $400 adapter assembled with new connectors and new pins? ie: no splices?
                        • matt
                          • 3731
                          Yes.
                          • whowhatwhere
                            • Aug 2007
                            • 259
                            If they are buying new from bmw, then they probably make $200 on each harness.
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              R&D + Mfg + Parts = $400.00
                              0 + 0 + Parts = <$200.00
                              I say fair deal, $200.00 is less the cost of a new windshield as you get pissed off and repeatedly slam a pair of wire strippers/soldering iron thru said windshield.
