AKG's adapter
  • 1990m3
    • 1180
    #31
    FYI: AKG converted my harness (He is local) and everything has been fine. A little over two years and no issues whatsoever. Best money I spent on my swap, no headaches
    • turboeta
      • Aug 2007
      • 571
      #32
      Originally posted by golde30
      make yer own.
      I might, I hate wiring though...lol
      Plus, for $200 its really no big deal. Whats another couple hundred when I've already spent about 5k on the motor/turbo setup. :)
      635csi Euro/Alpina B7S
      • Jean
        • 18228
        #33
        THR does make the adapters for the early cars with the square plugs btw.
        "We make the adapter so that you can plug one end into the engine and the other into the chassis and start it up! Certain cars and motors require a few extra wires that you may hook up - for example: 88 and 89 e30's have an oil level sensor in the dash so we have a separate line to run for that. We do everything possible to utilize evey wire in the harness so that the least amount of wiring is necessary for you, the installer. It will work generally speaking on any M50 motor, but it is nice to know the year and model, but it's not necessary.
        let me know if you have any other questions
        Jon"
        • e30this
          • 3580
          #34
          I just bought a AKG adapter yesterday, should be here Friday from what tracking info says.
          I will post photos when it shows up and check it all out.
          I know of 2 people who just bought one about a month ago and they was both great looking and I didnt see any issues with it at all.
          We will see..
          • e30s52
            • Oct 2007
            • 5235
            #35
            any one have photo's? im thinking about buying one but want to see some pics first
            www.gutenparts.com
            • e30this
              • 3580
              #36
              This wife said it showed up today but I wont be home till late tomorrow night early sunday morning
              I will post some
              • japspecvr6
                • Apr 2005
                • 602
                #37
                Post that pic Brotha....
                M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                • turboeta
                  • Aug 2007
                  • 571
                  #38
                  Yeah, we need the pics...lol
                  • e30s52
                    • Oct 2007
                    • 5235
                    #39
                    PPPPIIIICCCCCSSSS now i want to see them before i order
                    www.gutenparts.com
                    • Charlie
                      kid tested, administrator approved
                      • 6686
                      #40
                      It's two pieces of plastic and some heatshrink, what exactly do you want to see? It looks an awful lot like the picture on their site.
                      -Charlie
                      Swing wild, brake later, don't apologize.
                      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                      FYYFF
                      • e30this
                        • 3580
                        #41
                        ok I finally got around to taking a peak at the adapter.
                        the plugs are used but cleaned and in very good condition.
                        The wires that was not spliced was pulled from the harness along with the pins in the connectors.
                        The wires that was spliced together was crimped then heat shrink over them.
                        Then all the wires was wrapped in electrical tape, and some plastic wire cover and then more tape.
                        For the 200 I have spent on this I think it was well worth it in the end.
                        Saves me a lot of time searching and splicing, now I dont have to worry if I fucked anything up.
                        • turboeta
                          • Aug 2007
                          • 571
                          #42
                          Pics?
                          • ZiMMie
                            • Jun 2004
                            • 968
                            #43
                            with all the infomation available on this forum and the ETM, poeple are still spending $400
                            for a stupid plug?
                            if i were to spend that much money, i will expect a full OBD1 harness with the C101 attached to it. maybe i should start making that. :)
                            ive wired of 8 or more M5X swaps and i solder all of those connection none of them has failed. Poeple talkin shit about soldering either dont know how to solder properly or jst read too much on the internet. as other suggestest, u need a retard amount of solder to affect the resistors of a wire.
                            www.stancefactory.com
                            • matt
                              • 3732
                              #44
                              for a stupid plug?
                              Repost.
                              Originally posted by matt
                              I wish treehouse had an exchange program where you send them a wiring harness and they put an e30 connector on it and send it back. I would be all over that. Well, not for myself, but I would tell everybody to do that.
                              And soldering is still not as good as crimping.
                              • FredK
                                • 14761
                                #45
                                If you have a good ratcheting AMP crimp tool and properly sized dies, definitely. But, this is ca$hlimited.
                                If you have access to these tools, great. If not, solder.
