Interest in a module to correct MPG gauge and OBC MPG?
  • daniel
    • 6703
    #121
    Originally posted by Hartge H26
    do you have one that will work north of the border Litre / km
    it shouldn't make a difference.
    http://instagram.com/dslovn.drives
    • Hartge H26
      • Mar 2004
      • 102
      #122
      how??
      fuel consumption MPG vs. KPL
      Distance to empty Miles vs. Kilometers.
      • hoveringuy
        • Dec 2005
        • 2684
        #123
        I can send it calibrated for Litre/Km, grams/meter or Kilograms of CO2 per 100Km.
        • Drew325is
          • Oct 2004
          • 520
          #124
          Lulz...I've always been using my correction module on L/100km. The conversion for MPG or L/100km is built into the OBC itself (have a look in your E30s handbook for instructions on how to change it around). Steve's module will work just fine - no need for geographic calibrations.
          • Spaz
            Crazy Canuck
            • 2276
            #125
            I alwasy thought the OBC does the converison internally since you can change the units of measurements?
            Edit: Drew Beat me to it
            Cam .W '91 325is
            Spaz's 1991 Alpine White???? S52 Build Thread...
            • stevesingo
              • Jul 2008
              • 3
              #126
              Hoveringuy,
              I have an M3 which will be running Motec M800 ECU. Can you tell me what type of signal the stand alone module requires (Switched to earth?)? I should be able to configure the Motec to switch an auxiliary channel to earth easy enough.
              Am I correct in saying the DME fuel output signal is 12Hz switched to earth, with pulse width proportional to load?
              Many Thanks in advance
              Steve
              • hoveringuy
                • Dec 2005
                • 2684
                #127
                The signal is switch to earth.
                Your Motec will already be providing the necessary signal... the injector signal. The frequency of the signal is directly proportional to RPM and the width of the pulse to injector duty cycle. So, 400Hz to 3500Hz is about right.
                • stevesingo
                  • Jul 2008
                  • 3
                  #128
                  Can I ask then, does the OBC require a signal that is switched to earth, directly proportional to RPM with the same pulse width as the duty cycle? If not what does it need?
                  Thanks
                  Steve
                  • hoveringuy
                    • Dec 2005
                    • 2684
                    #129
                    Thanks
                    Steve
                    Yes, basically.
                    It adds the amount of time that it is switched to earth as fuel consumption. The quicker your engine is turning, the more often the injectors are firing (frequency) and the harder you are on the gas the longer they are open (duty cycle).
                    The easiest way to get that signal is to tap directly off one of the injectors itself.
                    If the MOTEC is capable of generating a discrete signal just for that purpose you wouldn't really need the board, because you'd be able to adjust that signal in MOTEC to get accurate mileage.
                    • stevesingo
                      • Jul 2008
                      • 3
                      #130
                      I will look in to thatn.
                      Many Thanks
                      Steve
                      • owenjm
                        • 237
                        #131
                        sent p-pal need one for e30 - s50
                        thanks looks like an excellent +++ product
                        owen
                        • hoveringuy
                          • Dec 2005
                          • 2684
                          #132
                          Nice looking cab! I see you went with the MAF at the 10 O'clock position... it really does make a difference.
                          I'll have the board out to you ASAP. The newest version is slightly nicer than the original with silk screened component graphics.
                          Hoveringuy
                          • JinormusJ
                            • 6887
                            #133
                            What was the site to order these at?
                            JK
                            Found it
                            • lmoorefx
                              • Dec 2010
                              • 4
                              #134
                              Trying to find one of these, seattlecircuit.com doesnt seem to exist anymore. Anyone have a line on this?
                              • yngtmr
                                • Mar 2016
                                • 88
                                #135
                                I would also like one of these, subbed for an answer
                                84 325e, Saphirblau Metallic/Houndstooth Sport, OBD-2 M52B28/ zf320
