jumping idle when warmed up
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    well im pretty sure its not a vacumm leak. i did the stomp test and i get 1216 (throttle position switch) any way i can test it? i dont want to buy a new one and not have that be it as its like $75
  • Van Westervelt
    • 9365
    Did you clean the ICV? Mine was a little sticky, after I cleaned it, no jumping around.
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      ill have to double check. did it only happen when the car warmed up?
      • whiltebeitel
        • Apr 2007
        • 2098
        I've had this happen twice. It randomly went away, and I think it was because I wrung it out a little bit that the idle returned to normal.
        '89 325i track sloot
        '01 530i daily
        -Enginerd
        • BDSax
          Junkyard King
          • Mar 2006
          • 3594
          explain??
          • FredK
            • 14762
            wrung out = driving it hard
            • whiltebeitel
              • Apr 2007
              • 2098
              Yes. Well, most specifically, I start the car (warmed up) and the idle bounced from 1k to 2k, it was like it was revving to race someone, but I was entirely off the throttle. So I try restarting the car, deos no good. I try accerating in a low gear to ~5k, and after a few minutes of this, it stops. It put it in first, no gas, it rolls forward and jerks when it revs. Strange sh*t.
              '01 530i daily
              -Enginerd
              • BDSax
                Junkyard King
                • Mar 2006
                • 3594
                sounds like we have the same problem. if I'm idleing at a light and release the clutch real quick it will go away. I'll have to give it hell when my exhaust is done
                • whiltebeitel
                  • Apr 2007
                  • 2098
                  I'm going to dig in there eentaully and see what is dirty, and see if that makes a difference.
                  '01 530i daily
                  -Enginerd
                  • BDSax
                    Junkyard King
                    • Mar 2006
                    • 3594
                    well, i took the ICV out. i thought i cleaned it but it wouldnt even move when i wiggled my hand. i have to pry it with a flat head screw driver to break it free. no more jumping idle!
                    Now it seems like its idling to low. could that be because there is no back pressure from having no exhasut yet?
                    • matt
                      • 3732
                      How low is too low? It should be pretty happy around 700RPM.
                      • BDSax
                        Junkyard King
                        • Mar 2006
                        • 3594
                        not sure, got late and my light doesnt work and my RPM jumps around. ill find out more tomorrow when i go get my exhaust done.
