Just a quick fuel related question
  • B3M2W5
    • 283
    Ok small dumb question, When hooking up the fuel lines where do i put the fuel pressure regulator vacuum line to...? Im having trouble with this.
    And just to clarify the line Comeing from the Fuel pump (obviously) would go into the fuel in let port (front) of the rail.
  • B3M2W5
    • 283
    Ok now its a little diff, I forgot about the charcoal canister. What lines go where, I am searching right now but if some one can help me out a little bit i would really apreciate it.
    Is the fuel evap valve nessasary ??
    • B3M2W5
      • 283
      OK bump any one shed some light on me. EH
      • matt
        • 3731
        You need a short vac hose from the fuel pressure regulator to the barb on the bottom of the intake manifold.
        As for the charcoal cannister stuff, keep the valve hooked up to the wire, but ditch the rest.
          • 37829
          What's the reason for keeping the valve plugged in? I ditched everything.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • matt
            • 3731
            It'll throw a code with some software if it isn't there.
