I can not get my m50 to run in a closed loop. The o2 sensor is reading .5 or whatever the bottom of the voltage range is, and it is brand new. The only other code I have is the air temperature sensor which is reading 162C, I will replace that this week, could that be making it run in a open loop. What do the 2 female connectors on the o2 sensor harness need to be connected to?
stuck in open loop!
162c = 323*FMy 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games. -
Thanks again MattComment
Not that I know of... the O2 sensor seems to hook up just to the M50 harness. Did you wire it properly? White to white, black to black, and the two grays can go either way since the heater is a resistive element.
Now... having wildly "off" values of the other sensors might prevent the DME from going into closed loop... not sure. I'll ask Mike when I get a chance.Comment
