530 remote reservoir question
  • 318isbmw
    • Nov 2005
    • 2843
    I've been searching and haven't seen an answer yet, but with the remote reservoir, what do you do with the line which goes into the reservoir itself on the e30 from I think the manifold? Any help would be much appreciated. If this line goes elsewhere, where should I plug it in or do w/ it.
    Thanks,
    Brendan
    • 37833
    Three lines will to to your remote res.
    Two go to the brake master cylinder and one goes to the clutch master cylinder.
    Grover Beach, California
    BimmerHeads.com
    • 318isbmw
      • Nov 2005
      • 2843
      Ok, so that is for the clutch master cylinder, now how should I tie that in, since it only has the two remote lines coming out of it? Should I build a little container for the clutch master cylinder line seperately?
      This's the part. Its pn# 34-32-1-160-576
