S52 Stock Exhaust Clearance Problem, Ebay Header?
  • Ohio1985e30
    • 29
    The stock exhaust manifold from my S52 runs into my front subframe of my 85 318i. I think I can use the ebay headers I read about on this forum to get over the subframe, but I wanted to make sure before I order them. Thanks. Pictures would be great.
    Doug
  • Jordan
    • 12916
    What engine mounts are you using?
    https://mtechniqueabs.com/
    • EtaSport
      • 2853
      yea, that doesnt make sense. an s52 manifold should never get close to the subframe. the downpipe probably will, but not the actual manifold. If you have fitment issues with that, then the ebay headers will def. hit. mine touch the subframe but i didnt use the shims that were included with the headers.
      Old and improved:
      • LINUS
        • 2422
        22 posts = he meant downpipe.
        Ebay headers are well documented, and when mine rubbed my subframe I kinked the header once I knew how far to kink it.
        Stainless is infamous for the level of warpage when welding 2 pieces. It's a pain to build spoolpieces for refinery applications if you aren't aware of that. It's an art form to place your tacks in such a way to end up with a straight piece going into your buildup passes.
        The good thing is there is nearly an exact science to the travel you get, so you can actually compensate for twisted pipe/settled equipment if need be.
        It's not how you handle the good times, but the faith you keep in the bad that defines you.
        • smonkbmw
          Professor
          • Jun 2006
          • 4549
          id be curious on the mounts hes using also. i fit the obd2 manis using the m5 mounts with tons of room.
          • thebmwM
            • 174
            So don't use ebay headers?
            • Van Westervelt
              • 9365
              ebay headers work and clear fine.
              • Ohio1985e30
                • 29
                thanks
                Thanks for the help. I did mean the down pipe will hit the subframe. We just looked at the manifold and could tell the down pipe will hit...abouth half the pipe will hit. I think I bought e28/5 series mounts, but need to check on that. Looks like I'm going to pick a set of the ebay headers and go from there. Thanks for the help.
                Doug
                • LINUS
                  • 2422
                  It depends which time zone you are in.
                  • gazellebeigem3
                    • Jun 2005
                    • 3712
                    Im using obd2 manifolds and downpipes, no clearance issues after using the treehouse CABs. It must be a mount issue.
                    • smonkbmw
                      Professor
                      • Jun 2006
                      • 4549
                      or get the proper motor mounts and CABS and go from there.
                      • So Live
                        • 2512
                        quick question... ill delete this post when i get an answer.
                        thats the OD of the pipes here:
                        thanks!!
                        -Chris
