So... we should benchmark NA motors against turbos?
S52 dyno results - low?
There seem to be 2 BOSCH PN's for the 24 lb/hr rated injectors:
0280150947
0280155917
The second seems to be the more prevalent one mentioned here, which is the Gen III 24lb design from Bosch. I'll be on the hunt for a set of those.
Now, the real question is: how did this result in my running *rich* above 6k RPMs?
1987 325i Cabrio - SOLD
2014 Chevy Volt
2007 FJ CruiserComment
You are correct, I have some mystery injectors. The only documentation I found on these was that they flow 200cc/hr, which is ~ 19 lbs/hr.
0280150947
0280155917
Now, the real question is: how did this result in my running *rich* above 6k RPMs?Comment
These are the slimmer updated plastic housing ones that turner sells. I have a set in my s50 right now.sigpicComment
