Fucking a man all that work and a dead batt killed your first time start!
Swap: M3 e30 + S50 Pics inside
o thats not good. Have you done a leak down test? also a compressionTial, Precision, Garrett Dealer!!!
PM me for more info.Comment
Hi Taper. Don't turn that motor anymore.
Do a compression test to isolate the "bad" cylinder. The one with the highest (to the roof) compression will be the cylinder where coolant leaks. Then remove the head and measure how warped it is. Most likely, if the head is only warped, you'll need to remove the cam boxes, then have the head pressed back to close-to-spec, and then milled/planned. If the head is badly warped, it means the cam box are warped too and the cam are not going to spin freely. Look for sign of wear on the cam journals/bearings.
I am currently going thru the exact same process after "one of the kids" was so excited doing its first race, he forgot to watch the water temp and ran a very expensive 350hp race engine, coolantless for half a race... The head is warped by 0.75mm in the center.Brake harder. Go faster. No shit.
massivebrakes.com
owch!Hi Taper. Don't turn that motor anymore.
I am currently going thru the exact same process after "one of the kids" was so excited doing its first race, he forgot to watch the water temp and ran a very expensive 350hp race engine, coolantless for half a race... The head is warped by 0.75mm in the center.Comment
http://l0st0n3.mybrute.com
http://l0st-0n3.mybrute.com
Work in progress: 1991 318i m50 swap
Feedback thread :up:
Originally posted by slammin.e28guyI prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.Comment
