My problem is getting the stock 90 325i cable to work, there has to be a better way than ghetto vacuum hose and collars. Do we know which cable will work nicely to set up cruise on my s50 e30?
The stock e30 cable doesn't slip into the rubber grommet at the bracket on the TB, and it's too long, if I modify it, I would worry about the cable catching, and sticking the throttle open. The cruise cable just sits idle while the main cable is pulled during normal driving.
Can the e36 cable be made to work?
What did you use?
Thanks
-Dan
What did you use?
Thanks
-Dan
