Temp gauge... argh
    • 37829
    Temp gauge... argh
    My temp gauge has never worked. When the ignition is on "run" and the motor is off, the temp gauge will peg out at the red. Once I start the car, it goes back to nothing and stays there. I know for a fact that the car is running at the temps it should be, no problem there. I replaced the gauge sensor with a brand new one today and no luck.
    Any insight? My next step is another cluster. After that, time to check my wiring I guess.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • Jason89i
    • Sep 2004
    • 875
    a little to vague. it would be helpful to know what you did, year of car to help diagnose. cheers, jason
    • Mike B.
      • Jan 2006
      • 987
      Are you running an OBD-II to OBD-I conversion?
      • static
        • Oct 2005
        • 501
        just get an aftermarket gauge - the stocker is almost useless anyway
        • cahomey
          • Mar 2004
          • 1201
          are you sure you have a e30 temp sensor?
          "It's like a koala bear crapped a rainbow in my brain."
          R.I.P. Harry Goz aka. Captain Murphy
          "My ride, My ride, she don't beg, steal, cheat, or lie,
          My ride, My ride, and our relationship is classified."
            • 34839
            yeah, that's the solution - something isn't working, so just hack the old one out and replace it with a cheap aftermarket gizmo.
            • BDSax
              Junkyard King
              • Mar 2006
              • 3594
              im guessing a bad gauge
              • ldsbeaker
                • Aug 2004
                • 3098
                SI board?
                Slicktop City!
                • static
                  • Oct 2005
                  • 501
                  where did you see "cheap" or "gizmo" in my post? if he already is spending time chasing this problem, might as well upgrade the temp indicator to something more meaningful than the factory 'idiot' gauge.
                  IMO of course.
                    • 34839
                    IMO of course.
                    this isn't the E36 - the gauge actually moves with the temp. the only difference is an aftermarket one has numbers. yay!
                      • 37829
                      It's an S50 in my 89. The sender is an E30 part and the SI board is fine.
                      Grover Beach, CA
                      www.BimmerHeads.com
                        • 34839
                        doesn't the temp gauge have the nut on the back for the ground wire?
                        • asubimmer
                          • 6482
                          shitty wiring prob
                          • lateapex31
                            • 79
                            Kinda backwards logic don't you think? Pull out your multimeter (you have a DMM, don't you? Anyone working on a car should have one), and check the resistance from the cluster to the sender and check for continuity to ground and +12V. It's probably a short that can be resolved by fixing it or at least pulling a new wire. Hold off on buying a new cluster....
                            • WillisE30
                              • Jan 2007
                              • 831
                              You may have an issue at your C101 connector, I don't recall which wire(s) dealt with temp signal but that would be the first thing I'd check. I know I had a few wires incorrect when I started my swap the first time. I still haven't bothered to fix my oil level sensor wiring, but that's another story.
                              sigpicFormer professional wrench thrower.
                              Current:
                              1988 325is S52
                              Former:
                              2008 Sparkling Graphite M3 Sedan(victim of home ownership)
                              1988 M5
                              1996 328is
