Wiring harness differences for eta?
    The tach wire is in the c104 which is a 3 pin connector in the glovebox area. I am pretty sure all etas have one. In which case you shouldn't need any length of wire at all just splice it in.
    If you have an econo gauge or an obc then you will want to hook up the fuel rate wire. It will not be accurate but your gauge will work. (my s50 gets like 57mpg hwy!!)
    Old and improved:
      Originally posted by lolcantturn View Post
      My coolant gauge gets power but it doesn't build up, I'm using an eta C101 to an E36 M50 one. Is this a fault of the ETA's C101 or simply a wiring fault of mine?
      You using an E30 sensor?
      Check Us out on Facebook
      Full Product Line Tuning
        Nope, E36 one. Am i supposed to use an E30 one?
        EDIT: Yep I am, just googled it. weird.
        Originally posted by TSI
        OEM+
          Holy back from the dead thread. I started this almost 4 years ago when I was first going to do a 24V swap and had to abandon it.
            well i have power now to the 3 relays. Yes i had a power wire connected wrong :|
            but im still not getting spark. Oh and I checked and i have confirmed power to the fuel pump relay.
              pin 24 on the e36 goes to the red/yellow wire of the c104
              pin 14 on the e36 goes to the black wire of the c104
              pin 20 of the e36 goes to the wire on the back of the instrument cluster in the circuit board with the green covering that snaps onto the cluster.
              these three wires the last one [in 20 wich wire do i splic it in to on the back of the cluster i have the rpm byt didnt know i had to put one in the back of the cluster any help here
                The last one mentioned is a Vehicle speed signal to the ECU...
