Starting issues (no fuelpump)
  • 318isbmw
    • Nov 2005
    • 2843
    Car won't start, not getting fuel... I know the harness had the ews wire clipped, so I'm figuring I don't need an ews delete chip because of this. Please correct me if I'm wrong on this. I checked on the fuelpump relay I put 87 to 30 and it does start the pump so that is all good.
    Thanks
  • btec116
    • Jun 2007
    • 131
    You will not get engine running on that computer without full ews system, including the original key from the car.
    Either get the chip, or if you have the Siemens box, might be time to start looking for a new computer...
    • 318isbmw
      • Nov 2005
      • 2843
      So even though it was on an e36 w/o ews because the ews wire was cut it still won't work for some wierd reason.
      Kool, thanks
      • e30_kid89
        • Apr 2006
        • 489
        is it getting spark?
        -Check your wiring
        -Check if you got the supply/return lines the wrong way
        -Check your main relay and fuel pump relay, making sure power is getting where its supposed to
        -Check your crank position sensor as well becuase if that is shot = No start
        • 318isbmw
          • Nov 2005
          • 2843
          -Check your wiring
          I know its getting to the fuel pump from the relay, I started that, the rest of the stuff I'll check when I tow it home from the exhaust shop hopefully tomorrow night.
          ninja edit: also I checked the supply and return to see they are in the right direction.
          I disconnected one of the fuel lines and just held it while my dad cranked the car out of curiosity if it wasn't going because of air or was there w/ no spark.
          The wiring is this one:
          • e30_kid89
            • Apr 2006
            • 489
            hmmm....Is your check engine light when you turn the key to the "On" position (not start)?
            • 318isbmw
              • Nov 2005
              • 2843
              Yes
              • e30_kid89
                • Apr 2006
                • 489
                Alright thats good, does the fuel pump turn on briefly when you have the key on the on position as well?
                • 318isbmw
                  • Nov 2005
                  • 2843
                  Nope
                  • e30_kid89
                    • Apr 2006
                    • 489
                    I sorta had the same problem, no fuel/spark no pump prrming. I changed the crank position sensor and it fired up like it was nobodys business. With that faulty i know it will not start. Doesn't hurt to test it out.
                    • 318isbmw
                      • Nov 2005
                      • 2843
                      Ya, definitely will. Sadly tonight I took it to the exhaust shop so I won't have it back for a day or two to test that.
                      Ninja edit: what should the resistance be for testing the CPS?
                      Thanks
                      • PiercedE30
                        • Apr 2005
                        • 4220
                        Thanks
                        490-560 Ohms
                        My 2.9L Build!
                        • 318isbmw
                          • Nov 2005
                          • 2843
                          Originally posted by PiercedE30
                          490-560 Ohms
                          Thanks much, by chance do you have the resistance for the TPS sensor or does that need to be set to anything?
                          Thanks
                          New update on the not starting, turns out that the ews chip was left in the ecu, new ecu on the way so I can start the car.
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            4600 Ohms
                            My 2.9L Build!
                            • 318isbmw
                              • Nov 2005
                              • 2843
                              4600 Ohms
                              Thanks much, wasn't able to figure that out.
