Starting issues (no fuelpump)
  • 318isbmw
    • Nov 2005
    • 2841
    Still won't start w/ a non ews chip.
    • jrhaile
      • Oct 2005
      • 744
      Get remote starters and try to jump it.. I forget how they work but I know you put one on the starter and one of something else...
      • PiercedE30
        • Apr 2005
        • 4220
        Are you getting power at the fuel pump relay? what about a signal to turn it on?
        My 2.9L Build!
        • redhatpat
          • Aug 2005
          • 656
          Originally posted by e30_kid89
          Alright thats good, does the fuel pump turn on briefly when you have the key on the on position as well?
          Is it supposed to? Are you sure? I finally tested mine while troubleshooting a starting issue and mine doesn't come on briefly when I turn the ignition on. I've heard this before from several people on different forums, but finally read one post here on r3v today that it doesn't actually come on and prime the system. Does anyone know for sure if its supposed to come on for a couple seconds?
          • 318isbmw
            • Nov 2005
            • 2841
            No signal at turnon that I can tell, can't hear nor feel anything when I put my hand ontop of the pump. When I jump the relay it runs tho. Just found out tonight that my crank position sensor was bad, so that should help w/ the no fuel while cranking, but still mistified about why no signal on turn on.
            James, I'm confused by ur post... It cranks perfect, no fuel tho
            Its suposed to turn on for I believe 2 seconds when you turn the car to start.
            • PiercedE30
              • Apr 2005
              • 4220
              Well, if the crank sensor is bad, then the computer doesn't get a tach signal and doesn't send a signal to turn on the relay.
              My 2.9L Build!
              • 318isbmw
                • Nov 2005
                • 2841
                But shouldn't it still do the start up 2 second setup? Thought it should, I'll find out tomorrow though I guess.
                • scabzzzz
                  Estado de mierda de encargo
                  • 6871
                  crank position sensors magically go bad when placed in an E30. true story.
                  • scabzzzz
                    • 6871
                    when you put the ignition in position 1, it goes through a system check to make sure basic things exist first.
                    • 318isbmw
                      • Nov 2005
                      • 2841
                      It turned out to be the crank sensor and the fact I had the ews chip still in the ecu.
                      Thanks
                      • KangamangusDriver
                        • Aug 2005
                        • 1870
                        Glad to hear you got it running!!
                        • e30_kid89
                          • Apr 2006
                          • 489
                          -Check your crank position sensor as well becuase if that is shot = No start
                          :-D
                          • jrhaile
                            • Oct 2005
                            • 744
                            So it's finally running?!?!?!
