OBD I and OBD II knock(ping) sensors
  • turboeta
    • Aug 2007
    • 571
    I need two new knock sensors for my M50tu, I keep finding OBDII sets available for cheap...the difference is that they use one connector for both as opposed to a connector for each one. Has anyone modified the OBDII ones to work with both connectors?
    ..my random question of the day.
    635csi Euro/Alpina B7S
  • hoveringuy
    • Dec 2005
    • 2747
    I had the two side by side (OBD I and OBD II) thinking I could use the new one by wiring it to the older plug. The newer sensor uses an entirely diffent kind of cable and wiring from what I could see.
    I have a single OBDI knock sensor with a crack in the plastic. I don't know if that will cause it to throw a code or not.
    Hoveringuy
    • turboeta
      • Aug 2007
      • 571
      Hoveringuy
      Hmm..I guess that shoots that idea down. I'm not sure about the plastic either, I guess I'll just be junkyard/ebay hunting for a little while.
      • PiercedE30
        • Apr 2005
        • 4220
        If you can get the shielded wire with the plug all the way to the ecu then you should be able to replace the obdi wire/plugs. That's what I've got.
        My 2.9L Build!
        • lateapex31
          • 79
          Or just buy some shielded cable and run your own.
