320 booster/IX booster vs. stock which is better?
  • e30polak
    • 6136
    just as the title says guys...i'm looking into the IE BBK for front and rear and i wanted to see everyone's opinions on their brakes whether u have a 320 booster or the IX set-up. currently i have the 320 booster, but i want something better, so i want some feedback on those with the IX one.
    INSTAGRAM: @UNDR8D_EMPIRE
  • Bmjpv
    • Mar 2007
    • 561
    Stock booster
    Install the stock booster and modify the intake manifold. Than install the 25mm master cylinder, Very clean and simple .
    • e30s52
      • Oct 2007
      • 5235
      do you have any pictures of this modify manifold?
      www.gutenparts.com
      • Teaguer
        • Sep 2004
        • 6167
        He's talking about notching the manifold to clear the stock booster .
        • SWAPJUNKIE
          • Jun 2007
          • 30
          We use the stock booster and master and slot the holes in the firewall about 1/2" towards the outside. The top inside bolt will be close to the bracket, so we normaly only use the three other studs. Then trim the fins off the maniflod. If you use the taller motor mounts you have about a 1/16" gap.
          • WillisE30
            • Jan 2007
            • 831
            Interesting
            sigpicFormer professional wrench thrower.
            Current:
            1988 325is S52
            Former:
            2008 Sparkling Graphite M3 Sedan(victim of home ownership)
            1988 M5
            1996 328is
            • Bmjpv
              • Mar 2007
              • 561
              Stock booster w/s52
              I did a small write up with pics a while ago , look this up, might work for you ?? joe
              • DaN
                • 1265
                My experience with the ix booster sucks. Im currently running it now with the fins shaved on the intake, 1/4" spacers on both motor mounts, and It still rubs. I'm going to have to slot the mounting holes.
                The brake pedal feels the same as it did with the original booster.
                I used the DSM reservoir with 2002 lines and nipples, and the e34 540 clutch res.
                My advice is to slot the holes before you install the booster and motor, lol. Now I gotta pull the whole setup out.
                It seems like the stock booster would have worked better, with slightly less mods.
                • hoveringuy
                  • Dec 2005
                  • 2749
                  I'm at the point where I can start prepping for my swap that I am planning for the first week in March. I will definately consider slotting the holes.
                  My question is: can I swap the booster ahead of time and then swap the motor, or does the booster need to be out to fit the motor? It seems like it would be easier to install the motor without the booster but want to get an experienced opinion.
                  Hoveringuy
                  • e30polak
                    • 6136
                    well i fixed the problem with a vacuum reserve canister mounted under the shock tower and my 320 booster, now it feels better then stock...but i still have to figure out abs :(
                    • OrganicMechanic
                      • Jan 2008
                      • 1719
                      Originally posted by SWAPJUNKIE
                      We use the stock booster and master and slot the holes in the firewall about 1/2" towards the outside. The top inside bolt will be close to the bracket, so we normally only use the three other studs. Then trim the fins off the manifold. If you use the taller motor mounts you have about a 1/16" gap.
                      corrected spelling errors
                      I don`t like the idea of weakening the fire wall. With this approach it would seem to give the already thin metal less structure and add flex when your hard on the brakes.
                      join the E30 Cabrio owners gruppe
                      click here for details
                      • DaN
                        • 1265
                        You can install the motor with the booster in place, that's what I did.
                        Now I'm considering the 944 booster with a vacuum res.
                        Just not grasping the physics of the reservoir.
                        Isn't the pedal effort increased due to the less surface area of the booster size? It seems like a res would increase the volume of the booster, which would help with multiple applications, but not with effort? Anyone have an explanation?
                        • Mike B.
                          • Jan 2006
                          • 987
                          Yes, it doesn't improve efforts. But it keeps you from running out of assist.
                          I find vacuum reservoir is more beneficial for really small boosters (7") or engines with high overlap cams that don't generate a lot of vacuum to create assist.
                          • hoveringuy
                            • Dec 2005
                            • 2749
                            The initial effort is directly proportional to the surface area of the diaphram (and the initial vacuum). However, as the pedal strokes the vacuum acting on the diaphram decreases and the assist fades. The resevoir keeps the vacuum at a more constant level to keep the assist consistent through the stroke.
                            • surebimmer
                              • Jan 2004
                              • 978
                              Do you have any pictures of this? What vacuum reserve canister did you use. I haven't had much issue with my brakes. But one time at an autocross it felt like I didn't have any vacuum assist. I thought about adding a vacuum reserve canister from like Jeg's. That's what old hot rod guys do when they run a big cam.
