gasket maker/sealer
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    gasket maker/sealer
    since my oilpan exploded i need to replace it, i have the metal gasket with the rubber around the inside. would it be ok to just use it as is or should i add some of that gasket maker/sealer also? I dont really wanna do it because i dont feel liek pulling the engine totally out of the car, or maybe i'm just being lazy right now and it seems like too much work to add the sealer and trying to line it up up there.
  • Mike B.
    • Jan 2006
    • 987
    In the Bentley, they show 4-points on the pan where additional sealer is necessary.
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      i dont have a bently, care to take a picture and post it for me?:)
      • FredK
        • 14762
        You put two dabs of sealant where the timing cover meets the front of the block, and two dabs of sealant where the rear main seal carrier meets the rear of the block.
        Basically, where aluminum meets cast iron.
        • Mike B.
          • Jan 2006
          • 987
          ^ What he said... Thanks for the clarification, I was a bit brief with my post.
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            thansk guys
            • BigD
              • Jul 2006
              • 1085
              Is there anything bad about adding a bead of silicone all around? I'm paranoid about oil pan leaks so I cleaned the surfaces as well as I could and siliconed both sides of the gasket (with special attention to the metal alu/steel joints).
