How thick are your engine spacers?
  • windsor318is
    • Mar 2004
    • 688
    big D did you put the mounts in the same hole the factory ones sit in?on AKG they use the slotted hole for the mount locations, maybe that lowered yours a tad from that...
    • BigD
      • Jul 2006
      • 1085
      No that's what I did too - the other way requires elongating the primary hole. That would actually put the engine higher, since they're closer together so the rake wouldn't be so great. I'll see, maybe I didn't even need the driver's side spacer. Perhaps if I take it out it'll fix things, if all I really needed was some elevation on the exhaust side.
      • Aussie M3ti
        • Apr 2007
        • 6
        Originally posted by Mike B.
        So you took the plunge with the euro... Nice! (what did you use for a brake booster? PM me.)
        I didn't notch my subframe and had to use 3/8th inch spacers to clear the headers. I have a spare subframe that I may notch depending on how it handles at the track.
        Mike, with those spacers did you have to any other mods to fit the euro headers?
        Thanks
        Brian
        • Mike B.
          • Jan 2006
          • 987
          Thanks
          Brian
          Just the spacers, and you have to knock in the passenger side firewall a bit.
