Oil pump priming
  • kroberts
    • 680
    Oil pump priming
    When I used to build mopar engines I had a oil pump priming shaft I'd put in a drill to pre-oil the engine. Is there a way to prime the oil pump in my six? Is it possible (or necessary)? I was thinking about pouring a quart slowly into the oil filter housing but I already have six in the engine now.
  • PiercedE30
    • Apr 2005
    • 4220
    Well, since I recently was able to start my motor, after a factory fresh rebuild, I needed to find a way to prime the oil system.
    So here is what I did:
    Remove plug going to DME.
    Ensure that the motor has oil.
    Proceed to start the car, only it won't start since the ECU isn't plugged in.
    I found it very helpfull to have a oil pressure gauge handy and to keep a jump box on hand.
    My 2.9L Build!
    • kroberts
      • 680
      What you're describing is just what I'm trying to avoid. The idea is to get some oil up into the mains BEFORE you turn the crank. No biggie.
      • PiercedE30
        • Apr 2005
        • 4220
        If everything still has the assembly lube on it, it should be good. That stuff takes a little while to be cut down by oil.
        My 2.9L Build!
        • WillisE30
          • Jan 2007
          • 831
          As far as I know there's not simple way to prime these engines, unlike old V8 motors where you could pull the distributor and prime away.
          sigpicFormer professional wrench thrower.
          Current:
          1988 325is S52
          Former:
          2008 Sparkling Graphite M3 Sedan(victim of home ownership)
          1988 M5
          1996 328is
          • nismoman
            • Jul 2006
            • 246
            yes do as you describe, pull the oil filter cap and pore one quart of oil in the filter housing. and then pore your 6 other quarts in the filler cap. then pull the relay with the green/purple tracer going to it. and crank away! it should only take about 5 full seconds of cranking for the oil pressure light to go off. then your ready to go. if you are not building pressure then make sure your dipstick is fully seated. also you can sort of prime the system by putting a air nossel to the dip stick tube and giving it a couple of blast. i would do that last though. for i dont know if thats such a good idea, just seen it done and it worked.
            1985 s50b30, 91 front and rear valence, e30 m3 suspension, advance design coilovers, GC camber caster plates full solid bushings alla round, adjustable rear arms, ireland sways front and back, ireland big brake kit front and back , team dynamics wheels, 24lb injectore ltw fly, intake , headers, exhaust, so forth so on......
            • matt
              • 3732
              There is no way to pressurize the oil system without turning the crank on these motors.
              Just crank it over 5 seconds at a time and watch your oil pressure. With cold oil, it doesn't take much.
              • e30serg
                • Dec 2006
                • 562
                couldn't you also put a wrench on the vibration damper bolt and spin away?
                • e30Matt
                  • 5077
                  Why do that when you accomplish the same by spinning the motor over with the starter, and don't get all sweaty and nasty in the process? :)
                    • 34844
                    I don't think you're going to be able to spin it fast enough by hand to generate any pressure. lol. ever done an M20 valve adjustment?
                    pull the fuel pump relay, crank the motor for a few seconds, done.
                    • m_dudey
                      • 267
                      i just want to say that adding the quart of oil in the oil filter housing worked! started cranking and in less than 5 seconds, I got oil pressure!
