where do the 2 valve cover nuts with the studs for coil ground straps go? i cant recall where the went in the middle like this stud---nut---nut---stud ? thanks!
valve cover nuts w/ground stud?
I put the two studded ones on the outside.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
ok i think i have this all wrong.... i have 3 grounding straps in the bag with all my valve cover hardware. 2 skinny ground straps and 1 fatter ground strap, all 3 are pretty short like 3". now i cant remember where these straps go, i thought that the 2 skinny ones connected at the valve cover and to the coil, but now that i think about it i seem to remember the straps connecting one coil to another.... what am i missing here?IG: @Baye30
the coils also ground through the valve cover. OBDI covers only use one ground strap all the way up against the firewall and OBDII covers use two ground straps, one on each end. it really doesn't seem to matter. Like Matt, i've run a few different configurations and can't seem to tell the difference between any of them
