Head stud question
  • So Live
    • 2512
    Head stud question
    Hey guys, just wondering if it was possible to put a head on with studs installed in the block all while bolted in an e30. Kinda thinking about upgrading to mls and studs but i dont want to take the engine out or lift it up at all.
    thanks!
    -Chris
  • matt
    • 3732
    I would think it would be a PITA. You'd have to modify the battery tray, I think.
    The other question... why do you think an MLS and studs will be an "upgrade?"
    • Borat
      • Jan 2005
      • 494
      you can install the studs after you have put the head and gasket back on, then tighten the nuts up.
      • So Live
        • 2512
        15 - 20 pounds of boost + MLS = upgrade.
        True, thanks for the idea borat
        -Chris
        • So Live
          • 2512
          So no one has a 24v e30 with studs and tried putting the head on the motor in the car?
          -Chris
          • matt
            • 3732
            I have a 24v e30 with studs, but I built my motor on a stand.
            I seriously think you will NOT be able to put the head on over the studs with the block in the car. I think you MAY be able to thread in the studs through the head, but I wouldn't count on it... it's a pretty delicate process setting the studs in the block just so, so they still wobble and don't bind and break as you torque them.
            • So Live
              • 2512
              Yeah. thats kinda why i was wondering but i can see where your coming from with the assumption of not being able to but i was hoping someone would know for sure.
              Oh well. I guess with exhaust manifold and the intake manifold off it wouldnt be too bad of a job to lift the motor up to vertical. Well see, i have to get the car running on boost first :)
              -Chris
              • So Live
                • 2512
                For future reference... I just found out you can put the head on with the block all bolted in the car and studs installed.
                and i quote "yeah the head went back on with the engine in, and head studs installed. i think this is my new preferred way of assembly. it makes the engine / trans assembly really easy to drop in. i've had the head off a number of times (unfortunately) and there is plenty of clearance to get things together even with studs." Multiplex on BF.c
                -Chris
                • matt
                  • 3732
                  You can also put the studs in after the head is on. I actually helped do it today.
                  • So Live
                    • 2512
                    right on. so we have options.
                    Looking at multiplex's build, he has the corner of the battery tray cut out for his downpipe. Maybe that helped too.
                    -Chris
