I have a M50NV can i use a e36 flywheel and clutch and starter. with a getrag 260?
325es m50VN
Originally posted by 0000000000 View PostI have a M50NV can i use a e36 flywheel and clutch and starter. with a getrag 260?
caution. that is an early 260. check out the thread.
NOT ALL 260'S ARE CREATED EQUAL
be careful with the early 325es trans.....its different than the 325i trans.
cheers, jason
ok i read it, it didnt really make any sense to me. what i got was that the early 260 had a dual mass flywheel, and the late 260 had a single mass. You tried to use a single mass in my car and it was hitting the e34 oil pan bolts so you had to grind the flywheel down to compensate this made the flywheel too small so its 3/16 to slim for the clutch fork to relase the clutch. so what you did is you welded a 3/16" on the throw out bearing to disengage the clutch. right?
so if i wanted to use a late 260 i would need to use a e36 flywheel, clutch and starter?Last edited by 0000000000; 02-13-2008, 09:58 AM.
Originally posted by 0000000000 View Postwhat i got was that the early 260 had a dual mass flywheel, and the late 260 had a single mass. ?
Originally posted by 0000000000 View PostYou tried to use a single mass in my car and it was hitting the e34 oil pan bolts so you had to grind the flywheel down to compensate this made the flywheel too small so its 3/16 to slim for the clutch fork to relase the clutch. so what you did is you welded a 3/16" on the throw out bearing to disengage the clutch. right??
the dual mass flywheel assembly (fly,, puck, plate) is thicker than the single mass flywheel assembly. SO....fork/throwout location is farther back on a dual mass getrag260.
now, to fit a single mass flywheel (lightened or not) in here (like on your car) you will need to either 1. move the fork / enlongate slave rod. or 2. increase stacking height of the clutch assembly.
i did number 2. added a spacer between flywheel and crank (+4mm +/-) and enlongated the throwout bearing tabs (+7mm +/-). i think you could also use an 84 323i throwout bearing. the old 323's had a single mass flywheel, the same old trans and a longer throwout bearing. i think thats how they got the lightened flywheel / clutch combo to work.
Originally posted by 0000000000 View Postso if i wanted to use a late 260 i would need to use a e36 flywheel, clutch and starter?
you would remove the spacer, put in a stock throwout bearing and use the late style slave.
EDIT: also wanted to mention that the output flange (holds the guibo) is a different size, i think the center support bearing was different, and so was the clutch slave cylinder.) all from memory, im getting old, just something to verify.
cheers, jasonLast edited by Jason89i; 02-13-2008, 10:36 AM.
