for those running the e30 m3 wiring harness covers
  • hugh jass
    • 2220
    how the hell did you get the harness wires compact enough to squeeze under the main cover along the firewall? i don't know how i can possibly make the wires smaller to snap the cover on. any tricks on routing the wires to make things work? thanks.
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
  • 1990m3
    • 1180
    cut out some unnecessary bulk from the harness and use lot of zip ties. It's hard and takes a long time
      • 37829
      I just got my covers, going to put them on this week. :)
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • smonkbmw
        Professor
        • Jun 2006
        • 4549
        If you have a auto harness its almost impossible. I dunno if you want to take the risk of cutting out something, never know might need it later. On mine i had the cover snapped shut on the front, but not the rear. Looked okay but not perfect.
        • Mike B.
          • Jan 2006
          • 987
          Try fitting a RHD Euro harness - it's next to impossible! I ended up have to use a couple zipties to hold things closed.
          If you do some trimming to the baseplate and ziptie the harness every couple of inches, it should fit with no issues.
          • hugh jass
            • 2220
            after about a hour yesterday i have almost everything fitting. i had an auto harness and i removed the auto harness plus and wiring. i moved the relays from the passenger side to the relay holder on the cover above the intake manifold and cinched everything down with zipties. i also had to trim a bit of the cover above the intake manifold. i have it fitted and just need a little bit more room on the passenger side to get the last clip to fasten.
            • Mot
              45 toting redneck
              • 4018
              With my e34 harness my only complaints are the main engine harness has too much rubber on the block parts to smoothly fit into the cover for the center piece, and my damn harness is so short it took me an hour of tugging and getting creative, to finally get enough of the harness into the cabin for my dme to bolt into the 318iS dme mount... I never realized how much shorter the e34 harness really was.
              • PiercedE30
                • Apr 2005
                • 4220
                I cut away a LOT of the harness. I removed the plug and wiring for the HFM, purge valve, diagnostic plug, automatic tranny, O2 sensor, I mean a lot of unnecessary wiring since I am using MS2/extra. I still ended up using a shit ton of zip ties to compress the wires to a reasonable state and still had to use zip ties to hold the cover in place.
                My 2.9L Build!
                • 1990m3
                  • 1180
                  I also used one zip tie on the outside of the cover to hold it together. i got it to snap together without the zip tie, but with force. I was afraid the vibrations from driving on the track might pop it open, the zip ties prevent that from happening.
                  • BeirBrennerE30
                    • 2740
                    you dont need about half the harness... start cuttin and everything fits fine
                    e30sport.net
                    '06 M3 Competition - 6-speed
                    '97 Range Rover Vitesse
                    • drifty340i
                      • Oct 2004
                      • 1076
                      Im not going to use the bottom plate on mine, just some how rig up just the cover
                      sigpic340hp V8 e30 FINISHED!!!!!
                      Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
                      NEW One on the track :)
                      http://www.youtube.com/watch?v=K-AX5SzSLnk
                      Cleaning up some 911s and Jap turbos
                      http://www.youtube.com/watch?v=Ad79wsLdle4
                      • gazellebeigem3
                        • Jun 2005
                        • 3712
                        I had an auto harness and cut a good chunk of it out. That and zipties.
                        • hugh jass
                          • 2220
                          did your emo harness cry when you cut it justin?
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            lolz
                            My 2.9L Build!
                            • japspecvr6
                              • Apr 2005
                              • 602
                              Man O Man i Still Have pack in my garage. Its to hard...
                              M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
