switched 12v source for abs pump
  • hugh jass
    • 2220
    Can someone tell me a convenient switched 12v source for my abs pump? The treehouse racing adapter has a lead for abs power but I'm not sure where to hook it up.
    Electrical is my achilles heal.
    Thanks.
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
  • golde30
    • 11464
    HA. when i was done making my harness, i had the ABS wire sticking out also not knowing where to hook it up...
    IG: @Baye30
    • ZiMMie
      • Jun 2004
      • 968
      Find a constant +12V when the Key is on,
      fuse it and attach it to it.
      www.stancefactory.com
      • hugh jass
        • 2220
        i know, i'm asking what a convenient source of switched 12v power is. anyone?
        • fretburnr
          • Jan 2005
          • 1496
          Is the connection at the fusebox for ABS (originally) not an option? That way it's already fused.
          Otherwise, at the fusebox there's an external prototyping area (smaller black box) that should have switched +12v somewhere.
          Jay
          • Jason89i
            • Sep 2004
            • 875
            90+ airbag cars have the abs power wired directly off the main relay.
            if you search, its here. but here's the answer again.....
            Power comes from the main relay (red/yellow) to the c101pin20 and then to the abs pump and abs relay. the m50 harness does not provide this wire. but, you can wire it similar to the factory. on the m50's, typically the red/white wire is a switched power (power at "on" pposition.) on the m50 harness, tap into the red/white at the main splice (where 6-5 red/white wires come together) and add a large gauge wire (same size as the red/yellow) and fish it into the c101p20. viola. abs.
            cheers, jason
            • hoveringuy
              • Dec 2005
              • 2733
              Concur. I ran mine to the red/white in the main splice box. No probs...
