need some advice
  • static
    • Oct 2005
    • 501
    Originally posted by BigD
    My problem is putting down a great guy and a master mechanic for something so stupid. If you expect him to check every bolt on every part he's going to put into your car, you don't think the money he charges for the swap should be more like 5x higher? I'm not saying you badmouthed him directly but jumping on the bandwagon without the other side having even presented their case is not cool. That's just me though. Maybe your dad strips down every car he works on to check the type and grade of every bolt (or he knows by smell - which I admit, knowing his work, is possible) but other people make some (normally) safe assumptions. What's next, expecting him to xray all of the internals for stress cracks? It can be done, but not for like a grand.
    Whatever though, sounds like there's more to it than initially stated but I still don't believe he would have done this and without hearing his side, which we probably won't, I don't want fellow E30ers (esp those from the GTA) taking this as gospel. If nothing else, a man of his integrity would have fixed this without a peep if it was brought to his attention before the internet.
    nice backpedaling! you make strong statements, using words like "low" in my address, and now you 'whatever' once proven wrong? good going! Guess you don't hold yourself responsible for the statements you make. I hope others will be smart enough to realize value of such statements in future.
    • static
      • Oct 2005
      • 501
      i just got off the phone with the mechanic
      indeed it was him who put the bolts in, but, according to him, only because the thread inside the block was too big to take the M8.
      I know for fact tho that the thread inside wasn't proper SAE, as the threads on the SAE bolt i took out was all mangled.
      • static
        • Oct 2005
        • 501
        update: decided to chase threads with a tap. Chased, then drove the proper M8x1.25, pulled the threads right out while torquing
        well, it's better to see those threads pulled in garage than on a track...
        helicoil time
        • B3M2W5
          • 283
          IM not a fan of helicoiling, I would just for tap it out to next size bigger and go with actual threads in the block... Just my opinion i am not a fan of helicoinling tho i just feel unsafe with them...
          • static
            • Oct 2005
            • 501
            why do you feel unsafe with them? just curious
            it's been scientifically proven that helicoiled threads are usually few times stronger than the threads in the original medium (in addition to spreading the load on individual threads more evenly).
            btw, from my brief research, the helicoils were invented to fix stripped threads on airplanes. I say if it's good enough for planes, it's good enough for a car ;)
            • Mike B.
              • Jan 2006
              • 987
              Helicoils are plenty safe if installed properly. Just be sure to use the proper drill bit size as specified on the package.
              • B3M2W5
                • 283
                True, i guess im just a little superstitious about them...Idk just my feeling i guess haha.
                • matt
                  • 3732
                  Time-serts are better...
                  • Mike B.
                    • Jan 2006
                    • 987
                    True... Time-serts are a solid threaded insert as opposed to a coiled spring.
                    • static
                      • Oct 2005
                      • 501
                      well thanks for telling me this after i ordered the perma-coil kit
                      meh... i just wanna get it over with
                      EDIT: there is a very insightful discussion comparing various inserts here: (and helicoils apparently still have advantages over other kinds)
                      • golde30
                        • 11464
                        how come you cant just tap it out to the next size up and use bigger bolts??
                        IG: @Baye30
                        • static
                          • Oct 2005
                          • 501
                          less drilling i suppose. Plus i already got good m8 bolts for this. Also the geek factor ;)
                          • btec116
                            • Jun 2007
                            • 131
                            Will M10's go through the mount arms?
