Center bearing and guibo question
  • e30this
    • 3580
    ok since Im using the M42 tranny and the e36 5 speed drive shaft can I use the e36 center support and guibo?
    Thanks
  • matt
    • 3732
    No and maybe. What kind of M42 transmission?
    • windsor318is
      • Mar 2004
      • 688
      i dont think you can use that tranny.
      • Lost
        • Jan 2008
        • 10
        There was thread couple of weeks ago in this section, that it's possible to use getrag 240 (318is gearbox) for the swap.
        -240/e36 transmisson mounts
        -323i throw out bearing
        -Use the pilot bearing that was ment for your motor
        -Driveshaft Center Bearing (e30 318is)
        • matt
          • 3732
          WRONG. Pilot bearing must match the TRANSMISSION, not the motor.
          • Dave
            E30 RAT
            • 11675
            i heard jordan is having fabulous success with the 240 he used with his swap . . .
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
            • 1990m3
              • 1180
              if by fabulous you mean it blew almost immediately, then yes he did.
              it looks like he might be foolish enough to put in another one. I guess he'd rather save money and spend all his days replacing gearboxes than just doing it right the first time:
              • zav3n
                Curious George!
                • Mar 2007
                • 223
                its too wide you need the e30 one thats what i used and it works just fine
                • e30this
                  • 3580
                  Yeah Yeah you can use the tranny.
                  I got all the pieces I need and the motor in. I just needed them last 2 pieces.
                  Well other then to finish the exhaust, install the rad and the 318 wire cover.
                  pics about a day old now. :)
                  Jordans motor is also the e36 M3, So doesnt it put out more power??
                  Not much Im sure but I dont plan to beat on mine like he did.
                  Thanks for the info guys..
