Ahh.. F'n radiators.
  • loonibab325i
    • Dec 2005
    • 770
    So my radiator has a crack in it.. I realize this AFTER I finally put radiator fluid in the car.. Anyway, I called 1800 radiator and I got a price quote for an e30 318is radiator and a e36 m3 one, my question is.. what is the best radiator to buy?
    The e30 one costs 184, and the e36 m3 one costs 187.. Basically the $ isn't the option, I would like to know which is the best route though.
    Thanks,
    -Abe.
    s52 0-150mph & more http://www.youtube.com/loonibab325i
  • FredK
    • 14761
    If your donor car is a 325i, get a E30 325i or E36 325i/M3/328i radiator, since you'll already have an expansion tank separate from the radiator.
    I bought my radiator from radiator-ac-imports on Ebay. The Behr radiator came double boxed and very securely packed, and was $136 shipped.
    • Roadsterd
      • Aug 2005
      • 195
      Where is yours cracked? I have an extra 318 radiator in the garage that just needs a new expansion tank (~$20).
      ---1991 M50 Powered More Door
      ---1990 Slow Calypso Cabrio
      ---2002 9k Rev Honda
      • loonibab325i
        • Dec 2005
        • 770
        well, I wouldn't want the 325 one because the car is a 318is and i would like to have the overflow on the radiator to make things cleaner.
        What fan setups are you running? And what is your opinion on what I should do? IE, radiator and fan setup?
        -Abe.
        • FredK
          • 14761
          Ah, I didn't see that you have a 318is. The 318is radiator can be had for around $139 from the same seller, including expansion tank. People that run the smaller radiator haven't really complained about having overheating problems, even though some of them live in hot climates.
          • golde30
            • 11464
            buy it on ebay, waay cheaper. also, what the hell is "radiator fluid"...LOL
            IG: @Baye30
            • So Live
              • 2512
              lol. You know my set up :)
              -Chris
              • loonibab325i
                • Dec 2005
                • 770
                HAHA. wow.. i got pwnd.. *coolant.
                • loonibab325i
                  • Dec 2005
                  • 770
                  i tried searching, couldn't find it.. can you link me?
                  -Abe.
                  nvm: I found this, will this do?
                  http://cgi.ebay.com/ebaymotors/New-B...ayphotohosting
                  • 318isbmw
                    • Nov 2005
                    • 2841
                    I'd go regular 318 radiator. W/ the lower temp thermostat my m50 sits right by the first of the 3 marks in the middle of the temp gauge.
                      • 37829
                      I've got the 318is radiator and a 16" Spal fan on the front. I barely even need the fan! I'm thinking of swapping to a lower temp thermostat though just to keep it even cooler.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • Roadsterd
                        • Aug 2005
                        • 195
                        -Abe.
                        Just bought that same one two weeks ago... fast shipping and works as it should.
                        No a/c, right?
                        • Mtriple
                          • 3139
                          Ireland radiator and 16 inch spal pusher. Nice to have the extra cooling capacity especially if you're going to track it down in your region.
                          Originally posted by Simon S
                          • B3M2W5
                            • 283
                            I went with the E36 M3 rad.
                            Altho i believe you might have fan issues if you run the normal engine fan. I went with a fan delete.
                            I still have yet to install an aux fan but i havent even had issues with it yet. Still doesnt even get upto temp stays first line to the left.
                            I plan on going an aux fan and running water wetter for the summer tho.
                            • e30_kid89
                              • Apr 2006
                              • 489
                              MR 325, you used a 16" fan on yours? I put on a 14" on my m42 rad and it covered the whole thing!
                              To the OP, if you use the m42 rad, lower temp T-stat, electric fan and some water wetter you should be golden.
