Ahh.. F'n radiators.
  • PiercedE30
    • Apr 2005
    • 4220
    Damn, I went over board and got the MZ3 S54 triple core with a 16" pusher and no A/C. I normally see temp of about 175 driving around and that highest it has got has been like 199.
    My 2.9L Build!
    • Roadsterd
      • Aug 2005
      • 195
      When did you see 199? TX gets just as hot as LA, if not hotter in the summer. Now you have me worried about running the little 318 radiator.
      ---1991 M50 Powered More Door
      ---1990 Slow Calypso Cabrio
      ---2002 9k Rev Honda
      • PiercedE30
        • Apr 2005
        • 4220
        I saw 199 when I had to make a trip to the bank for work around 3. I think it was like 85* last week when I went. I had to wait in line for about 15 minutes to make the deposit. Hell, at the AutoX, turning off the car between runs, I was only seeing about 185-190. But I was getting serious intake air temp heat soak, I think it got up to about 130 and I had my hood popped between runs with my fan running.
        My 2.9L Build!
          • 37829
          Ya, almost positive it's a 16", barely fit on there.
          And yes, no A/C.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • Roadsterd
            • Aug 2005
            • 195
            The stock aux fan is ~15" across. It looks like I could fit a 16" in the stock location even with the condenser in place. You say the 16" barely fit without a/c? :?
              • 37829
              There's probably an inch extra at most if I remember right.
              Grover Beach, CA
              www.BimmerHeads.com
              • golde30
                • 11464
                i just used a new Behr m20 radiator, and 75deg T-stat with a 12" spal pusher, and my car stays super cool. actually i only need to turn on the fan if i hit traffic or am in an area with stop signs on every single block.
                IG: @Baye30
                • So Live
                  • 2512
                  Ill get you the part number when im home (idk my com crashed, might not have the spread sheet anymore)
                  But you can get an aux fan temp switch that goes in the radiator that turns the aux fan on at about half on the gauge. Its perfect.
                  I have the 318 rad, 75* t-stat, 2 bottles of water wetter, and that fan switch. I run at 1/4 and in traffic it gets to 1/2 where the fan kicks in and it goes right down to 1/4
                  Ill get actual deg numbers when my cars running again :)
                  -Chris
                  • PiercedE30
                    • Apr 2005
                    • 4220
                    The fan switch is the 80/88 temp switch from the 95 318ti. It's the same one I am using. It RARELY actually has to come on. Then only time I have actually had it come on on its own was when I had the car running just sitting while I was working on it.
                    My 2.9L Build!
                    • BDSax
                      Junkyard King
                      • Mar 2006
                      • 3594
                      dont want to thread jack, but does the e30 318 radiator not have a fluid level sensor?
                      • 1990m3
                        • 1180
                        no fluid sensor. The 318is did not have a check panel, at least mine didn't.
                        • Roadsterd
                          • Aug 2005
                          • 195
                          Yeah, no check panel on the m42 cars. No coolant level sensor or oil level sensor.
                          • So Live
                            • 2512
                            If your anal about the light and dont want to take the light out, you can jumper the pins.
                            Yeah, i wasnt sure what year or car the switch came from thanks!
                            -Chris
                            • BDSax
                              Junkyard King
                              • Mar 2006
                              • 3594
                              yeah i already did that. i just like having things work
