Wiring up EWS
I'm running EWS II on my '84 E30 M52 Euro swap. Got the pin-outs from Ian Haynes, and it fired first turn...sigpic
BumbleE30 M52 2.8iComment
why do people still want EWS? For these cars, its such a simple system that you could jump the signal wires between the module and bypass the system completely....making it completely worthless.
If you want to have fun with wiring and have an anti-theft system, why not wire in a hidden fuel pump kill switch? There are many other easier approaches than using an outdated antitheft system.
Don't think you understand ews2 and above. You can't hot wire around it. Yes you may be able to get the starter to fire but the ecu won't ever fire fuel/spark.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
With a ECU flash or emulator yes.
