if so share some light before i tackle the etm.
Anyone got thier Code (OBC) to work after the swap?
Ha. You do realize that the power for the ecu is fed through a relay controlled by the OBC and is a completely separate system from the ECU harness, right?
I had to find out why my car wouldn't start one weekend and found out that the OBC relay had a bad solder joint on it and caused my problems.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
