"Fan delete mod"
  • dude8383
    • Jan 2005
    • 10387
    Originally posted by E30 Groupie
    I dont see how not having any fan is even feasible for a street car.
    You are running the electric fan though right Matt?
    My post was somewhat misleading :)
    What I meant to say is that I want to run the stock AUX fan that is in front...without having to add an electric fan like a Spal or something.
    If its a bad idea I'm open to suggestions because I'm still in the process of building.
      • 37828
      Originally posted by loonibab325i
      Matt, where did you get all your parts for the conversion?
      -Abe.
      Through my work of course. :)
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • zav3n
        Curious George!
        • Mar 2007
        • 223
        o0o0 too bad i already had that fan relay from jegs.... nice sig pic btw
        • surebimmer
          • Jan 2004
          • 978
          I'm also running no fan with the 75* temp t-stat, Water Wetter and lower temp 80c e36 318i aux fan temp switch. I also used the stock aux fan without the a/c condensor. So I had to mount them using euro brackets.
          Here is the post on how to mount stock aux fan with euro brackets:
          Make sure you get the correct one for your plug type. See picture below.
          • Mike B.
            • Jan 2006
            • 987
            Great mod!
            btw - I have a set of euro brackets that I never used, so if anybody wants them please PM me. Just a few bucks plus shipping.
            • So Live
              • 2512
              In my 318 rad i used the 75* t-stat, 80/88 switch and water wetter. Works great.
              -Chris
              • NC325iC
                • Mar 2004
                • 6565
                Originally posted by MR 325
                I have a nice Spal on the front of the radiator wired in to the stock wiring. It comes on by itself as needed. :)
                resurrection
                what model fan do you have
                • btec116
                  • Jun 2007
                  • 131
                  Basic, but what temp does the standard T-stat switch at? Is this mod OK in summer traffic? Does anyone keep the original AC rad and electric fan with this combo?
                  Cheers.
                  • golde30
                    • 11464
                    so i was in traffic yesterday with 99deg heat wave, and with my electric fan on and the above mods, my car almost made it to the half-way mark.
                    IG: @Baye30
                    • BeirBrennerE30
                      • 2740
                      Oh, I think the thermostat I got is the 75 degree also.
                      I thought you were running no fan at all. I tried that for about 2 weeks until I hot some traffic and almost had a nuclear melt down.
                      You need at least an Electric fan if you do this mod!
                      e30sport.net
                      '06 M3 Competition - 6-speed
                      '97 Range Rover Vitesse
                        • 37828
                        Nah, you have to have the elctric fan. It really barely ever comes on though.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • grib
                          • Oct 2006
                          • 151
                          Yea, but I think carbon fiber lets more heat through... :p
                          I have a 14" Spal with the Understeer kit. It pretty much has to kick on whenever I come to a stop, and the needle does creep up a bit.
                          Have not taken my e30 out into the heat wave yet...
                          1987 325i Cabrio - SOLD
                          2014 Chevy Volt
                          2007 FJ Cruiser
                          • Charlie
                            kid tested, administrator approved
                            • 6686
                            Which Part # are you guys using for the 75 degree t-stat?
                            -Charlie
                            Swing wild, brake later, don't apologize.
                            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                            FYYFF
                            • clavinZERO
                              Hella sick E30
                              • Mar 2004
                              • 2027
                              Part numbers for the thermostats, via WorldPac:
                              71 degree: 11 53 1 466 174/71
                              75 degree: 11 53 1 466 174/75
                              80 degree: 11 53 1 713 040
                              Part numbers for the radiator-mounted thermo (temp) switches (aka Aux Fan Switch):
                              91/99 degree (stock on late model E30, 3-pole @ top-right of radiator): 61 31 1 378 073
                              80/88 degree (from E36/M42 motor apparently, same connector as late model E30): 61 31 8 361 787
                              SIDE NOTE:
                              I am doing similar mods this week, and I am putting a SPAL 16" Puller fan in on the engine side, mounted to the fan shroud somehow. I am going to wire it to the LOW speed power for the aux elctric fan, but I will bypass the resistor. I will let you guys know how she runs on some hot days. I have the 80 degree thermostat but the lower temp fan switch.
                              Matt and Cary... how have the HOT days been?
                              "BMW Style 32 Poster-Child"
                              HTTP://WWW.CLAVINZERO.COM/e30-5-lug
                              **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
                                • 34839
                                if you are going to bypass the resistor, I would wire it so only the high speed comes on - I'm not sure the low speed circuit can handle the current draw. 13amps has been no problem for my high speed circuit though (I carry spare relays too).
