13: O2 Sensor Circuit
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    I can't figure out how to get the voltmeter on the ECU contacts though, if I pull the back cover off the plug it just comes unplugged and creates a whole new set of codes...
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • equate975
      • Jun 2004
      • 3382
      Well you don't want power to it when your checking for continuity. So pull the battery cable off, unplug the ecu, and check from there.
      Rollin' with a Geistkuchen
      • hoveringuy
        • Dec 2005
        • 2722
        Let me know what you find. I have a similar problem... I get a "O2 heater" CEL occasionaly when I idle for a while. I've checked and replaced everything with no change.
        • Fidhle007
          • Oct 2005
          • 7209
          I thought you were saying to check for voltage with the engine running?
          • equate975
            • Jun 2004
            • 3382
            No, continuity. Put your voltmeter on ohms so that it beeps when you touch the 2 leads on it together.
            Pull the ecu off and stick one lead in where the o2 signal goes. Then go to the o2 sensor and touch that wire.
            If it beeps that means that the signal is going from a to b. Test each wire just to make sure everything is connected right.
            You CANNOT have voltage on any of these wires or your going to blow your meter.
            All of this will just 100% verify all the wires are going to the right place.
            • Fidhle007
              • Oct 2005
              • 7209
              Ok, that seems simple enough! Thanks!
              • Fidhle007
                • Oct 2005
                • 7209
                So after a month of ignoring the Check Engine light I finally get around to checking continuity. Pins 13 and 40 check out fine and neither seem to be grounded out but I don't have continuity from 87 on the O2 heater relay to pin 1 (I think) on the sensor plug. This obviously means I'm not getting any power to the heater but wouldn't this throw a more specific code? It should still be able to manage the car once everything is warm though and I'm not completely frying my motor, right?
                Now it seems to me, the simplest fix has to be to just run a new wire straight from the relay plug to the sensor plug, right? I was going to go ahead and do this tonight but I chickened out as I have an AutoX tomorrow and didn't want to fry anything.
