Info on 540i MAF / Euro HFM
  • m3_eater
    • 413
    On a related note: aren't any gains provided by a 3.5" MAF/HFM going to be erased by running the stock 3" airbox line into it? 3" to 3.5" and back to 3" sounds like a useless upgrade to me *shrug*
    E30 24V 6MT SOLD :( - look for it in sunny Miami :)
    • dude8383
      • Jan 2005
      • 10387
      i was thinking about this as well...
      is there a real difference with the 3.5" ??
      • chuck90m3
        • 568
        yes there are gain to be found with this set up, people dont just do it for SPORT. If you feel that you will see more of a gain with a 3.5" Suction boot then buy one from Bimmerworld there only $99.
        "A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
        Friedrich Nietzsche
        • rwh11385
          lance_entities
          • 18403
          Originally posted by matt
          Incorrect.
          The 540i/euro HFM is not compatible with OBDII. You need a porsche MAF and you need to wire it in a specific way... hence the TMS MAF harness that goes with conforti OBDII intakes.
          It seems like VAC found a way? https://store.vacmotorsports.com/mob...6-m3-p574.aspx
          I have a spare 540 MAF and 24 lb injectors and a M50 manifold - hopefully can find a way to have them play nice while keeping OBDII.
          • pazi88
            • Sep 2015
            • 584
            Yes the 540i/euro HFM can be easily used in OBD2 setup. Just change the connector, wire it correctly and use MAF map from alpina binary. The wiring isn't anything special. Just match wires according to the ETM.
