what do you think about this and does it work? has any one tryed it? here is the link to http://www.zionsvilleautosport.com/s...ry_Code=CCSE36
Temp Sender Manifold (OBDII to OBDI)
Our Temp Sender Manifold, a single piece machined from billet aluminum, allows the M50/S50 OBDI dash gage temperature sender to be used with an OBDII engine. This item is installed in the small coolant supply line that runs from the cylinder head to the throttle body. No more need to drill and tap the cylinder head when performing an OBDI Conversion!
Installation is simple. Just cut the hose and insert the Temp Sender Manifold. Secure it with a hose clamp on either side (available above). Install your temperature sender and plug it in. That's it.
Contact Us | Conversion Kits | Cooling Solutions | Featured Items | New Parts | Parts Request | Project Corner | Software | Used Parts
Copyright ©1996-2008 Zionsville Autosport. All Rights Reserved.
Zionsville Autosport does not accept liability for incorrect spelling, printing errors, incorrect specifications or changes by manufacturers, or grammatical inaccuracies relating to any product included in this website. Prices subject to change without notice.
Policies
Our Temp Sender Manifold, a single piece machined from billet aluminum, allows the M50/S50 OBDI dash gage temperature sender to be used with an OBDII engine. This item is installed in the small coolant supply line that runs from the cylinder head to the throttle body. No more need to drill and tap the cylinder head when performing an OBDI Conversion!Installation is simple. Just cut the hose and insert the Temp Sender Manifold. Secure it with a hose clamp on either side (available above). Install your temperature sender and plug it in. That's it.
Policies
