Originally posted by Stu Mc
The comprehensive DOHC engine swap thread.
This is a sticky topic.
Brew, you can do it that way as well. I don't know whether or not it is advantagous to mod the selector rod, or the lever. Seems to me that either method would be fine.Originally posted by BrewI need to do this. I was also thinking that I might just bend the shift lever itself. I don't know. :?Originally posted by Stu McCut it. Rotate it so the ends have a 10-degree difference. Weld it back together.Originally posted by ed94rStu,
One more question. When using the 260, how do you bend the selector rod? It's alloy and seems awful brittle!
Thanks,
Ed
trentComment
This is what we did on JasonH's and Bryson's conversions. It is quick, easy, strong, and most of all works very well. Send JasonH a PM, I'm sure he still has a pic of it before he installed it.Originally posted by Stu McCut it. Rotate it so the ends have a 10-degree difference. Weld it back together.Don't forget the good things Hitler did.Comment
WIring the vehicle speed sensor. Has anyone done it without that green plug? I dont have that on my cluster and I have tried connecting the grey wire to either output pin on the speedo with no luck. I have also tried connecting it to the brown/red which should be the input.
Im a bit lost because it always throws the code. Is there a common ground on the cluster, does it use a body ground, or do I need to then ground that other half of the circuit back to the ECU? I cant get a check engine light to work either.
I guess the other alternative would be to find what wire goes from the ECU to the OBC.Im now E30less.
sigpicComment
I've acces to an wrecked 1993 E36 2.5 really cheap and a couple months ago bites the M50 bug me
so here are my Q's :
I don't now much about M50 swaps so don't flame me
A 1993 car, has it the famous anti theft system (DWS or EWS )
Is it an M50 or M52???
and is the E36 wiring harness something worth in an E30???
TIA A.C.
1989 E30 318iS
_______________________________1989 E30 325iC M-Technic I
1997 E36 328iT
1990 E30 325iT 24v SOLD
1989 E30 325i 2.7i M-Technic II SOLDComment
if i'm not mistaken, EWS became an issue with '96+ engines, which had that and OBDII... 318ti guys dumping sixes in their cars usually had this issue with later engines. Basically you'd have to take your car to a stealer to get something with the computer reset.
a '93 325i is going to have an M50..
dunno about the harness though.1988 325iC - "Betty" - Daily Driver/Project Car.
1993 318i - "The Golden Dream" - Dad's Car.
1995 318ti - "Hellrot" - R.I.P.Comment
So it's an Vanos engine ?Originally posted by BrewIts an m50tu. M52 engines are OBD2, 1996+.Originally posted by BavarianBimmerA 1993 car, has it the famous anti theft system (DWS or EWS )
Is it an M50 or M52???.
Is it worth the money and labour for swapping into an E30 ???
Wich parts do I need basically ?
Here's a pic :
1989 E30 318iS
1997 E36 328iT
Ah fuck, now I'm really confused.Originally posted by Brysonhaha, you guys are talking about modifying two different parts, both of you are right.
the screwdriver will bend the upper shift linkage
I was talking about bending the actual shift lever, the part that the knob goes on.
'91 318is
sigpicComment
