Originally posted by DanGillan
The comprehensive DOHC engine swap thread.
This is a sticky topic.
Originally posted by BeirBrennerE30i have 2 conflicting wireing diagrams... that ill post right here since there seems to be a lack of info on this on this thred... everyone can debate which of the 2 diagrams is the correct one or maybe a hologation of the 2... so here it is...
e30 plug pin#.... to e36pin#(diagram A).... to e36pin#(diagram B)
1............................25................... .....................................25
2............................16................... .....................................16
3............................NA................... .....................................NA
4............................12................... .....................................12
5............................23................... .....................................23
6............................22................... .....................................22
7............................21................... .....................................21
8............................24................... .....................................24
9............................20................... .....................................20
10..........................10.................... ....................................10
11..........................19.................... ....................................NA
12..........................8..................... .....................................8
13..........................13.................... ....................................13
14..........................14.................... ....................................14
15..........................15.................... ....................................15
16..........................NA.................... ...................................19
17..........................NA.................... ....................................18
18..........................18.................... ....................................NA
19..........................NA.................... ....................................NA
20..........................NA.................... ....................................3
I am working on my harness adapter now also. Diagram A appears to be the AKG diagram with the edits done in this thread on Dec 14, 2004. Diagram B is on addissimo.com. The discrepancy is in E36 pin 18 and 19. On my car (1991 318is) the starter is pin 18. Slot 17 is an empty housing with no contact. So... e36 pin 18 goes to e30 pin 18. e36 pin 19 is still a mystery, but I will leave it out for now and test it later.
I am, however, unsure of the accuracy of the rest of Diagram A. It makes use of e30 pins 2 and 10, which are also empty housings without contacts on my car. Perhaps this is optional equipment my car doesn't have??
My car has the newer m42 engine, and may be different from the m20 plug setups. Perhaps this is why the diagrams are different? I'm not sure, so as easy-e once said, "don't quote me boy, cause I aint said shit."Comment
Originally posted by DanGillanyea, i did 18 to 18, and i didnt use e30 pin 20.
im trying to do an all inclusive writeup on the e30m50 swap and ive been getting very different answers on wiring...e30sport.net
'06 M3 Competition - 6-speed
'97 Range Rover VitesseComment
i think you'll notice that there is different information everywhere, for a couple reasons, e30 are fucking retarded. different models seem to have slight differences. i have e36 pin 19 hooked up to e30 pin 16. i have not yet started my car so i cant tell you what worked or didnt, i will as soon as i finish up.Dan
Originally posted by DanGillani think you'll notice that there is different information everywhere, for a couple reasons, e30 are fucking retarded. different models seem to have slight differences. i have e36 pin 19 hooked up to e30 pin 16. i have not yet started my car so i cant tell you what worked or didnt, i will as soon as i finish up.
i originally thought that a generic pin chart would work for all m20s but it turn out no to be the case so im trying to find out what as many people did differently in their own swaps to see what works in what models...e30sport.net
Originally posted by BeirBrennerE30i originally thought that a generic pin chart would work for all m20s but it turn out no to be the case so im trying to find out what as many people did differently in their own swaps to see what works in what models...Comment
^^ what he said
people... use the online info as a resource, but make your own wiring chart. make sure you understand it or when you run into problems as you're finishing the swap, they may be wiring problems, and if you dont understand the wiring, then you will be totally lost when trying to diagnose your problem.Dan
Originally posted by Jason89ii have wired a few swaps. they are all different. 86 is different from 88 is different from 89 is different from 90. every wiring diagram out there stinks. grab a $10 voltometer and the wiring diagrams. take your time, understand how the system works and figure out each circuit. make your own chart. DO NOT FOLLOW ANY ONLINE DIAGRAMS from others that dont understand how the systems work. and if you did cheat of someone elses notes, its probabily wrong. cheers, jason
welll screw the writeup then... everyman for himself... i should finish my 2nd swap tomorrow s50 325ise30sport.net
Originally posted by DanGillanin the bronzit?
the swap that i was trying to base my writeup on was into a purple(i dont think its a bmw paint code) '90 325is with an s50 in a friends care30sport.net
That's a lot of good reading!!!
I'm about to button my swap up tonight and minus the exhaust I think I'll have her ready to start... I have a couple quick questions for you experienced swappers though.
1. the power lead from the distrabution block to the starter - the e36 harness splits with one lead going to the starter and the other lead I think going to the e36 fuse box. I've used my e30 starter wire instead and deleted that from the harness. I couldn't think of anything I would need the second connection for - am I wrong in thinking this?
2. The inspection plug has 2 wires bundled with it. I beleive Ryan said one was the master ground and the other was power, hooked up to the distrabution block. Does this sound correct?Comment
Originally posted by iflytii1. the power lead from the distrabution block to the starter - the e36 harness splits with one lead going to the starter and the other lead I think going to the e36 fuse box. I've used my e30 starter wire instead and deleted that from the harness. I couldn't think of anything I would need the second connection for - am I wrong in thinking this?
Originally posted by iflytii2. The inspection plug has 2 wires bundled with it. I beleive Ryan said one was the master ground and the other was power, hooked up to the distrabution block. Does this sound correct?
cheers, jasonComment
Originally posted by Jason89icheck the wiring diagrams in the bentley. main power block wire on the 36 harness (large red one) splits into two large wires. one to starter, other to alternator. I have seen some harnesses not split. then, power block to starter, large jumper from starter to alternator.
color of wires would be helpful.
cheers, jason
The 2 connections in question are a bundle of brown wires (assumed master ground) and a bundle of red wires (obviously power). I've just answered my own question... :-DComment
