The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • asubimmer
    • 6482
    #751
    no you can leave the pedal in, I did. But it does make it easier to remove the booster w/out pedals up there.
    • bimerok
      • Apr 2007
      • 149
      #752
      oh.. the pin lock that holds brake pedal to the fork. You kind of spread it apart a little with a screwdriver and push it off the pin. it's hard to explain.... but look at it with the light and rotate it around and you'll figure it out
      Here is my horrible drawing representation of what that locking tab looks like. See attached.
      • windsor318is
        • Mar 2004
        • 688
        #753
        you the man, ill giver a shot. i gotta start my thread on here, then you guys can follow.
        • windsor318is
          • Mar 2004
          • 688
          #754
          next question, why do i need the overflow tank for the rad from the e30, why cant i use the e36 overflow, that attached to the rad?
          • bimerok
            • Apr 2007
            • 149
            #755
            I'm not sure if the one that is attached to the rad. on e36 has the output for the hose that goes to engine head like the one from e30.
            • Mike B.
              • Jan 2006
              • 987
              #756
              You don't. You can use the E36 radiator with the attached reservoir/overflow tank.
              • JRKOUPE
                • Dec 2004
                • 3159
                #757
                quick question on a swap...
                Im looking at an m3 e 36 engine from an automatic car.....to be swapped into my manual e 30 325i. Does this pose any addtl issues?......... I was assuming/hoping it was no issues whatsoever.
                thanks to all.........
                • FredK
                  • 14762
                  #758
                  No issues. You just need to install a pilot bearing into the crank. My engine and DME were from an automatic car. There's some additional reassurance that the engine was never zinged from a light overrev, so it won't be waiting to drop a valve on you.
                  • golde30
                    • 11464
                    #759
                    you have a 318is rite? just use the stock rad that came with yer m42, it has the overflow tank built in, so no need for an additional overflow tank.
                    IG: @Baye30
                    • windsor318is
                      • Mar 2004
                      • 688
                      #760
                      i love you, i didnt see anyone with that setup so i assumed i couldnt do that, now i dont need the ugly resouvoir tank! move shaving added to my list.
                      • BigD
                        • Jul 2006
                        • 1085
                        #761
                        There are some but it's not a good idea, especially in our climate. It will only be sufficient for winter and summer highway driving.
                        • windsor318is
                          • Mar 2004
                          • 688
                          #762
                          sure? even with the 80 degree t stat and fan delete? im going to try anyways, even though i do have the e36 one lieing around. i dont want that gay container
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            #763
                            Ha, because I'm in La I didn't even think of using a rad with a built in expansion tank. I went big and got the S54 MZ3 triple core and just got a new e30 expansion tank.
                            My 2.9L Build!
                            • windsor318is
                              • Mar 2004
                              • 688
                              #764
                              i hate canada... hang on there, l.a. is just as hot as here, why wouldnt i be able to run the 318 rad?
                              • Mike B.
                                • Jan 2006
                                • 987
                                #765
                                Just run the M42 radiator and if your temps run hot, install a larger radiator.
                                An nice, high volume electric fan will help the M42 radiator significantly. I don't think a 16" one will fit on the M42 radiator, so go with a 14".
