ZF transmission with a broken tab...
  • evil_twin
    • Nov 2007
    • 2965
    Anybody have the mounting tab for the transmission mount break? I received a transmission with a broken tab, could someone be able to weld a new one up there? Has anyone had this done before without the tab?
    Paypal: vdang5@gmail.com
    Delta Auto Care
    2875-C Towerview Road
    Herndon, VA
    703.435.1375
    My Feedback Thread: Evil_Twin
  • hugh jass
    • 2220
    This is pretty common. I've had mounting tabs rewelded on a couple of trannys. As long as the welder knows what they are doing, it is an easy repair.
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    • kroberts
      • 680
      Lemme guess...UPS strikes again? They broke one of mine then denied the claim. A good welder should be able to build it up, I'm told that ZF used high grade aluminum to cast their trans bodies and they take to welding well. Just be careful when it finished, it will never be quite as strong as before the damage.
      Easy fix, just ask around and find a good welder. Most automotive machine shops know one, or have one in-house.
      • hugh jass
        • 2220
        Actually, 2 pieces of metal that are welded together properly are stronger than the original piece. The trick is doing it right.
        • e30s52
          • Oct 2007
          • 5235
          mine broke off. i welded it back together in about 20 mins
          www.gutenparts.com
          • PiercedE30
            • Apr 2005
            • 4220
            Yea, like hugh said, a strong weld won't break. The metal surrounding the weld should break before the weld even comes close.
            My 2.9L Build!
            • gazellebeigem3
              • Jun 2005
              • 3712
              Word, see this at work all the time. Ive also seen them used broken at the race track where/when it cant easily be welded.
              • evil_twin
                • Nov 2007
                • 2965
                So even if I don't have the broken tab, a good welder can weld a tab on for me anyways... Nice..
                BTW, it was UPS, but I don't see the tab so I don't know if it was UPS or the seller :(
                Delta Auto Care
                Herndon, VA
                703.435.1375
                • mattdk318i
                  • Jun 2006
                  • 3953
                  if you were closer........Ive got the square wave tig machine,tungsten and rods.
