Longer throttle cable than M3 E30?
  • kristov
    • 222
    Does there exist any longer BMW throttle cable than the M3 E30 that will fit the E30?
    I need one that is about 4-5 inches longer.
    Any help greatly appreciated!
  • DCColegrove
    • 2748
    MMmm,
    I'm not sure but possibly an e28 M5.
    • e30s52
      • Oct 2007
      • 5235
      search
      www.gutenparts.com
      • kristov
        • 222
        Originally posted by e30s52
        search
        Do you have some keywords that would yield the best results?
        • FredK
          • 14761
          I'm fairly certain that searching won't work, as few people need a cable 4-5 inches longer than the E30 M3 cable.
          Mike B. has said the E30 M42 cable is longer than the E30 M3 cable, but I am not sure if it is 4-5 inches longer. I believe the E34 525i M50 cable is longer than the E30 M42 cable.
          I am wondering out loud, maybe a RHD throttle cable would get you the length you need?
          • kristov
            • 222
            Does anyone have any measurements on the cables above?
            I can measure my E30 M3 cable but it's too short...
            • e30s52
              • Oct 2007
              • 5235
              just use the e34 cable for the m50
              www.gutenparts.com
              • FredK
                • 14761
                I think kristov is putting an S54 into his car, so the M50 cable may not work. I should be able to get a measurement for an M42 cable later today.
                • kristov
                  • 222
                  That is correct! With the VAC-kit I need a longer cable.
                  I would love to be able to use some sort of OEM BMW cable and not make something custom there too.
                  • FredK
                    • 14761
                    Unfortunately I don't think the M42 cable will give you the length you need. It looks to be 1" longer, with the overall length being essentially the same:
                    Top cable is S14, bottom cable is M42.
                    Detail: S14 top, M42 bottom.
                    The S14 cable does have a long rigid section at the end, around 3" in length. I don't think that would affect anything for your particular setup--bracket actuating a long throttle linkage.
                    • kristov
                      • 222
                      Thanks for your help FredK!
                      I was at my dealer today and he ordered some cables so I could see if some of they would fit.
                      We found a cable for E36 318is but it was way too long - almost double the S14 wire.
                      My dealer suggested that the E34 535i wire probably would be right. In a couple of days we will get some answers.
                      • JiXer
                        • 620
                        What did you ever find out about your throttle cable?
                        I need one about 6 inches longer than the M42.
                        J.
                        J. Farina
                        Yeah, thats me kicking up all that dirt!
                        • jahnaboi
                          • Oct 2006
                          • 1742
                          Kristov, you should try using a e36 325i (m50 motor) throttle cable. Its longer than the e34 m50 and shorter than the e36 318.
                          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                          • LINUS
                            • 2422
                            Just a suggestion in case you can't find a cable you like, but have the ends terminals you are comfortable running - How about using say a motorcycle throttle cable, brake cable, etc.
                            I've scavenged cables before from old, dead dirt bikes for different projects.
                            May not be a permanent fix, but it would buy you time to get running until you can research the most proper cable you want to run long term.
                            Or call Adzevo - if you ask real nice they might tell you outright what they use on swap cars.
                            It's not how you handle the good times, but the faith you keep in the bad that defines you.
