Hesitating above 6500...
    • 37833
    Once is a while when I take the car to redline it will start to hesitate starting anywhere from 6200-6500 and all the way to redline. I'm wondering if anybody has had anything like this go on with their cars and what may cause it.
    I'm thinking it's a fuel issue but of course haven't really looked in to it much at this point. It's definitely not a bad ground to the engine or coils. The wierd thing si I have been driving this car since November with the motor and this has only started to happen in the last couple weeks.
    Grover Beach, California
    BimmerHeads.com
  • BigD
    • Jul 2006
    • 1085
    How old is your fuel pump/filter? Me and windsor318is are having an extreme version of that. He knows it's his pump, I'm 99% sure it is (and/or filter).
    • matt
      • 3732
      Only once in a while?
      • e30polak
        • 6136
        If it's not fuel, it might have something to do with vanos?
        INSTAGRAM: @UNDR8D_EMPIRE
        • dark89e30
          • 263
          Ignition. OE plugs? VCG?
          • DCColegrove
            • 2748
            What engine are we talking about?
            I've had M52's and TUs float valves at high rev's when the oil was nasty.
            Bad coils, plugs etc can do it too under heavy load.
            • scabzzzz
              Estado de mierda de encargo
              • 6871
              In my M52 swapped car, my fuel filter was dirty and it did that. I had stock programming as well.
              • e30s52
                • Oct 2007
                • 5235
                its not vanos my m50 non-vanos did the same thing. i just replaced the fuel filter and it stoped.
                www.gutenparts.com
                • windsor318is
                  • Mar 2004
                  • 688
                  i think its a combination of pump and filter, we are forgetting how old these cars are. and its been awhile im sure since people have changed there filters.
                  • JPStrniste
                    • 146
                    fyi, a 1990 mustang 5.0 in tank fuel pump is less than $80 at any parts store and fits as a replacement for the e30 intank pump...
                    e30 intank pump is about $200 from dealer and about $180 for aftermarket
                    works great in my car
                    • BigD
                      • Jul 2006
                      • 1085
                      Could this pump work with an early, dual pump car? So it would work as the pre-pump? I've got both OEM pumps on order but they don't ship until tomorrow, I have time, pls let me know.
                      • e30this
                        • 3580
                        I had this issue with my m50 swap and it ended up being a bad combo of an 02 sensor and bad plugs.
                        • DaN
                          • 1265
                          I'd say no, it won't work as a pre-pump.The one in the tank on early cars just transfers fuel without much pressure. The one he's talking about Is a higher pressure main pump, and you don't need 2 of those.
                          • BigD
                            • Jul 2006
                            • 1085
                            Cools, I'll stick to OEM. Thanks.
                              • 37833
                              This is an S50.
                              Fuel filter, plugs, o2 sensor were all brand new when the motor was installed. Not sure of the pump's age, haven't touched it.
                              BimmerHeads.com
