Hesitating above 6500...
  • broke30
    • May 2007
    • 1019
    Does the car throw a code for it? And how sudden is the hesitation? Does it just "blip" in or is it long-lasting?
    Max
    • static
      • Oct 2005
      • 501
      i wonder if there is a way to check the duty cycle of your injectors during the troublesome rpm range - i read reports that original 17.5# inj are not enough for s50 with some high flowing mods (i.e approaching 100%) - are 17.5#'s what you have?
      otherwise, as others suggested, changing fuel filter is always a good thing, and the pump may not supply enough pressure at the high volume required after 6krpm/high load
      also may be something stupid like a kink in hard or soft fuel lines.
        • 37834
        No codes. I know the injectors are not the problem since it did it with the stock injectors and still does it with the S52 injectors. If I have time tomorrow I am going to test the fuel pressure.
        Grover Beach, California
        BimmerHeads.com
        • static
          • Oct 2005
          • 501
          not sure what your measuring strategy will be, but make sure to test it at the troublesome rpm/load range (i.e 6500-7000 full load). i.e not just at idle, as that won't tell the story
            • 37834
            Haha, thanks for the advice. ;)
            I will use the Mac fuel pressure gauge at work. Probably stick it under the windshield wiper and go drive it.
            BimmerHeads.com
            • static
              • Oct 2005
              • 501
              good idea!
              • matt
                • 3732
                Originally posted by matt
                Only once in a while?
                Matt,
                Could you reply to this please?
                Matt
                  • 37834
                  Matt,
                  Matt
                  Yes, it doesn't do it every time. I had this problem before the chip btw.
                  BimmerHeads.com
                  • e30s52
                    • Oct 2007
                    • 5235
                    did you fix this problem?
                    www.gutenparts.com
