It runs but won't stop!!
  • justin_l_
    • Jun 2007
    • 1079
    Man I was excited today when I finally got my m50 swap started! But now I have run into the issue that it doesn't shut off when I turn the key off. Anybody have any ideas?
  • etxxz
    • Feb 2006
    • 2085
    car year/model? definetly a wiring problem. check ETM where ignition goes to the ECU, maybe it thinks its always on the "ON" position and your ignition cylinder is only cranking the starter. check your ETM for 'dme power from ignition switch' (C101 pin 7 on my car -> X20 pin 21)
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
    • yberther
      • 1246
      lol
      Flickr
      Originally posted by Indecline06
      For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
      • justin_l_
        • Jun 2007
        • 1079
        84 325e > 92 nv m50. Man I hate wiring, it took me a week straight every night reading diagrams to get this far lol. I will have to take a few mins and look and see what i have. At least the fuel pump turns off when I turn the key off, but the dash lights stay on.... I HATE WIRING lol.
        • etxxz
          • Feb 2006
          • 2085
          e30><you
          91 BMW 325i [sold]
          • justin_l_
            • Jun 2007
            • 1079
            pretty much.... :???: btw I didn't forget about you, ko just sux and hasn't given me my money back....
            • etxxz
              • Feb 2006
              • 2085
              rolf!! u must have me confused with Erick (rwdrift) i'm a free lance jaja
              91 BMW 325i [sold]
              • yberther
                • 1246
                hey dude I'm actually doing the wiring for my 84 325e to a 92 m50 swap as well. how'd you go about doing the fuse box? (no plugs or anything??)
                Flickr
                • justin_l_
                  • Jun 2007
                  • 1079
                  I know your not erick lol. I was just saying ko hasn't gotten my money back to me yet for canceling my order. I need that money so I can buy more parts lol. I was interested in your exhaust but it doesn't seem like I am ever going to be able to save up enough money with this economy .
                  What exactly do you mean about doing the fuesbox? I haven't had to do anything to the fuesbox?! PM me and maybe I can help ya a lil more.
                  • tubby17s
                    • Nov 2007
                    • 85
                    car not turning off... hmm. be thankful that it turns on... just drive it and be happy.
                    Whys everyone have to complain all the time...lol
                    • BigD
                      • Jul 2006
                      • 1085
                      Try a different main relay? I'd say it's either that or ignition switch. There shouldn't be anything beyond that - regardless of how you may have screwed up wiring, if you cut the power (ignition off, main relay goes off) then nothing else matters...
                      • Jason89i
                        • Sep 2004
                        • 875
                        let me guess, you borrowed someone else's wiring diagram for an 87+ car.
                        EDIT: my bad. just read you did check the wiring diagrams.
                        your car wiring (85e) uses a different style start signal disconnect for the k5/k7 relays. if you look at the older "e" starters, it has two wires. if you look at the e36 and 87+ e30, they have three wires. the trigger wire (i think blk / green) for the k5/k7 is not present in your car. grab an etm (wiring diagrams) for both cars and start taking notes on the differences.
                        cheers, jason
                        • FredK
                          • 14762
                          Doesn't the 84e have a square C101? I don't think I've seen anyone's pinout for a 19 pin C101. I'm sure he looked at an ETM, because DME power is routed through pin 10 on rectangular C101 cars, as opposed to pin 7 on round C101 cars.
                          What would be helpful is if you posted up how you wired the C101 up.
                          • justin_l_
                            • Jun 2007
                            • 1079
                            Ok, I'm gunna go and check to see if there is still power at the main relay with the key off, and Will grab my adapter and post how it is wire up, any other suggestions while i'm out there?
                            • justin_l_
                              • Jun 2007
                              • 1079
                              Wiring for c101 is as follows:
                              E30-E36
                              1-25
                              2-?
                              4-12
                              6-13
                              7-13
                              8-18
                              10-21
                              16-23
                              I did a couple quick checks with the main relay. Bare with me as it is easy to confuse here-
                              Car not running. Key on, power to all but the 1 ground wire. Key off, power to the two solid red only.
                              Car running. Key on, power to all but the one ground wire. Key off, power to all but the one ground wire.(this is where the problem lies i believe.)
                              I did notice when you use a jumper wire from the ground on the relay to a body ground with the key on, the relay clicks, is this normal?
                              Thanks for the help!!
