It runs but won't stop!!
  • FredK
    • 14761
    You have it hooked up fine, except as far as I can tell, rectangular C101 pin 6 does not need to be connected to x20 pin 13. C101 pin 6 is hot in run and start and powers, besides the idle speed control unit, terminal 86 on the O2 sensor heater relay on the M20B27. When the M20B27 Motronic is powered, 85 is grounded and closes the heater relay.
    The E36 powers the oxygen sensor through the DME relay, so you don't need to hook up C101 pin 6.
    • justin_l_
      • Jun 2007
      • 1079
      So just disconect the O2 sensor wire (pin 6) and the ecu will still tell the sensor when to turn on and off?
      I picked up another main relay last night and am going to try that and see what happens in a little while.
      Thanks for the help guys, keep it comming if you have it!
      • justin_l_
        • Jun 2007
        • 1079
        Just tried another know good main relay and it did NOT fix the problem. Back to troubleshooting. Any suggestions are welcome and greatly appreciated at this point lol.
        • justin_l_
          • Jun 2007
          • 1079
          So I am a complete idiot and forgot to disconect pin 6 like fred said. Well, disconected it and it works like a champ. Hmmm.... now where do I run the wire to the O2 sensor? lol
          • FredK
            • 14761
            Which wire are you talking about? You can just tape off pin 6 on the C101, it doesn't need to be connected to anything.
            The O2 sensor is hooked up like normal, using the round plug, right?
            • justin_l_
              • Jun 2007
              • 1079
              Correct, I was talking about pin 6 on the c101. I will just tape it. Yes, the 02 is going to be hooked up to the round connector like normal. Thanks for the help, it is much apprecitated!
              • etxxz
                • Feb 2006
                • 2085
                victory! i was waay off.
                No more e30s for me.
                88 black BMW OBDII 332is dedicated track [sold]
                88 BMW OBDII bronzit 332is [RIP 03/08]
                91 BMW 325i [sold]
                86 Corolla 'Ae86' HB 20v trd [sold]
                http://youtube.com/watch?v=pTj7Hn9v5Rs
