Oil cooler questions
  • 416stroker
    • May 2008
    • 2448
    I was gonna set up an oil cooler on my m50 think it would work if I routed it threw an automatic transmission radiator. I think it might not flow good enough but I dunno i might just order a real one.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • PiercedE30
    • Apr 2005
    • 4220
    Why not just use the stock one?
    My 2.9L Build!
    • Bmjpv
      • Mar 2007
      • 561
      oil cooler ,Boom !
      Making your trans cooler into a engine cooler means it will go Boom ! Use the stock cooler.
      • 416stroker
        • May 2008
        • 2448
        my stock one got all fucked up due to the curb my g/f hit.
        I thought it wouldnt work one of my dads ideas to use the radiator. looks like i gotta go to pick-n-pull
        84 318I Delphin RIP
        89 325 Alpineweiss
        • hugh jass
          • 2220
          you can find used stock oil cooler here or on ebay very easily
          ______________________
          ex-Chief Operating Officer
          Blunt Tech Industries
          West Coast and Pacific Rim
          • Jean
            • 18228
            416stroker , I am local and have one with lines for sale $60 for you.
            http://cgi.ebay.com/ebaymotors/ws/eB...m=290244636551
            • Van Westervelt
              • 9365
              How and what lines are you planning on running to the stock oil cooler?
              • 416stroker
                • May 2008
                • 2448
                Im gonna just make my own custom lines with an fittings to an aftermarket cooler.
                84 318I Delphin RIP
                89 325 Alpineweiss
                • PiercedE30
                  • Apr 2005
                  • 4220
                  Maybe something like this?
                  My 2.9L Build!
                  • Van Westervelt
                    • 9365
                    Which plate/filter housing are you guys using? This is one of me next additions as the cams have upped my oil temps.
                    • PiercedE30
                      • Apr 2005
                      • 4220
                      I'm using a MZ3 S52 housing with the oil cooler ports drilled out so they actually work and had the back side of the return port (one closest to the front of the motor) welded up to force the oil through the cooler, since there is no thermostat. Either that or you can pick up an S54/Euro S50 oil filter housing.
                      My 2.9L Build!
                      • 416stroker
                        • May 2008
                        • 2448
                        I was gonna end up running Ireland enginerreing's oil cooler adaptor for the m50
                        84 318I Delphin RIP
                        89 325 Alpineweiss
                          • 37829
                          I was thinking about getting one too, anybody actually running the IE adapter? I was thinking of doing one of those with a nice big cooler from Summit and calling ti a day.
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • 416stroker
                            • May 2008
                            • 2448
                            I think im gonna do the same set up. +1 on the ie adapter.
                            84 318I Delphin RIP
                            89 325 Alpineweiss
